Old 04-15-2011, 03:36 PM   #1
JCD
JCD's Avatar
Another Center Bearing Question..
Not surprisingly my 72 C20 is making support bearing noise.
Since it's a daily driver, I wanted to order the parts before I took it apart.
They only had the smaller 1/2 ton bearing, at the local parts store, so I wanted to order from one of the suppliers.
This brings me to my question..
There's two diameters listed in the catalog.
1.3780" and 1.5748"
How would I determine which one I need, without removing the part?
I have the heavy duty rear leaf springs.
J.
1972 Custom Deluxe Highlander C20
1971 Javelin SST New Project
1971 Demon 340
1969 SS El Camino
1968 SS RS 396 Camaro
1967 Barracuda Formula S
1965 140/4sp Corvair Monza Convertible
Sorry, but I don't do Fords.
JCD is offline   Reply With Quote
Old 04-15-2011, 03:39 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Another Center Bearing Question..
If it's makin' noise... daily driver or not... you should just pull it an measure it. It will leave you stranded if not fixed.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-15-2011, 04:18 PM   #3
brad_man_72
the boat guy
brad_man_72's Avatar
should be the 1.3" horseshoe style braket.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 04-15-2011, 07:04 PM   #4
JCD
JCD's Avatar
Thanks for the response..
I have to send away for it..
so is there a way to be sure of this..measuring it on the Truck?
And what is the application for the 1.5" one?
J.
1971 Demon 340
1969 SS El Camino
Old 04-15-2011, 08:26 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You'll be better off taking it to a driveline shop. They can press it off (instead of hammering) and they have the stuff on hand 9 times out of 10, plus, it's better stuff than what the parts stores will have.
