305 v6 dip stick
I just got the truck and I went to check the oil and the tube came with the dipstick, but the tube looks broken. I just came from the junk yard and the guy had one but it was broken too. Can I weld this?
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here If you need any further assistance with that please contact any Admin for help. Last edited by Alan's Classic; 04-15-2011 at 06:01 PM. Reason: WTB |
Senior Enthusiast
Re: 305 v6 dip stick
I would suggest checking with/joining the Jolly GMC website. They are the experts on everything GMC V6:
http://www.6066gmcguy.org/ |
1 thing at a time is progress.
Sorry I had to edit your post.
If all else fails then weld it.
Alan
Philippians 2:14-16 |
Andy,
Some of them were that way at the factory, once you clean the parts you will notice that the longer tube fits perfect in the smaller tube. (99% sure) that was because the larger series truck that used the same V-6 blocks had a modifed oil dip stick (longer) The lip pressed around the longer male tube. This was GMC's answer to making the tube long enough to reach from up top. The older engine I had, had one like this. You can do two things, weld it up or put them together, bend the lip back over and put a smear of JB Weld on it , prime and paint. It sits so low on the block, no one cam see it clearly because it hides behind the exhause manifold. Also remember to use a clip to hold it against the block.
http://s1299.photobucket.com/user/jb...23904108567829 Last edited by jbgroby; 04-15-2011 at 08:06 PM. |
Kid's Mechanic
I have used a torch and brass on several small block tubes . Worked good for me .
