2wd to 4wd using 2wd frame?
Is it possible to convert a 2wd to a 4wd using the brackets off a 4x4 frame? The 4x4 frame we have is pretty rusted so I was thinking about cutting the brackets off and using the 2wd frame if it will work. Doing this on a 91 choo choo suburban.
Thanks, Kade |
Getcha Pull
Re: 2wd to 4wd using 2wd frame?
With the brackets, it is pretty straight forward. Here is a work log on Pirate. His is a bit more custom then I think you want, but it documents the process pretty good.
http://www.pirate4x4.com/forum/showt...hlight=2wd+4wd Another conversion. http://www.chuckschevytruckpages.com/robsK35.html
'81 K10 454/SM465 '86 S10 Blazer '95 H-D Softail '96 Integra |
Update: got the front and rear axles in. It really isn't that bad if you have a donor frame.
| Bookmarks |
