Old 03-24-2003, 11:36 PM   #1
72cheyenne402
Spindle Difference
Is there any difference between a stock C-10 and C-20 spindle?
72cheyenne402 is offline   Reply With Quote
Old 03-24-2003, 11:56 PM   #2
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
I believe the answer is "yes". If I remember right, the tie rod ends are different and the spindle shaft is different too. LMC catalog shows a C20 only spindle for 71-72. I don't know the answer for sure, but the clues say they are different. Also, I wanted to make sure your post stays on top so you get an answer. Did I mention I was bored and curious?
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
Old 03-25-2003, 12:25 AM   #3
crazy longhorn
Fabricate till you "puke"
Yup that is correct,& the balljoints are also larger on the c 20. Do you need swapover info, or just a source for replacment part?
crazy longhorn is offline   Reply With Quote
Old 03-25-2003, 01:13 AM   #4
72cheyenne402
Im looking to build my 72 c10 into a prerunner, and instead of building custom spindles I was going to machine out the ball joint holes and heim everything. Then I would build custom control arms to mount off the heims and onto my own bosses on the frame for the upper arm and the crossmember for the lower arm. So I was just wondering if there was any strength difference between the two.
