FInding the leak in my cab.
So I seem to have a leak in the back of my cab. I can't see water on the back walk, but I have a wet spot near dead center where the tank was. What is a good way to locate it? Where might it be from?
Everything is out of the cab right now.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
1961 crewcab
Re: FInding the leak in my cab.
maybe get in it with the doors shut and windows up, and have someone soak it with a water hose... maybe there is a rust pinhole in the roof or back window that is letting water in? maybe the seam in the rear window gasket is dried up and seperated?
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Resistance is Futile
My guess would be the gutter along the roof. I bet the seam sealer is cracked. All 3 of my trucks were this way. It must be chipped out and re-done if it's in bad condition.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#4 | |
No rain for the next 3 days, no time like now in this area. Thanks for the replies, lets hope it works.
