04-16-2011, 05:21 PM | #1 |
Wheel stud problem
The previous owner of my '67 installed late model 6 lug wheels. I found a nice set of the early 6 lug rally's and decided to put those on. When I removed the wheels I found he used 1" spacers and longer 1/2" wheel studs. The studs are too long for my rally's, so I started removing them and found all of them welded on from the backside. It appears someone drilled out the original bolt holes too much and the studs wouldn't grab. I thought about just leaving them on and trying to cut them to length. I'd rather replace them with correct size for the hole but I'm reaching dead ends trying to find them. The holes are just a tad over 5/8. Any help would be appreciated.
04-18-2011, 09:44 AM | #2 |
Restoration Virgin!
Re: Wheel stud problem
ttt
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
04-18-2011, 10:42 AM | #3 |
Redefining LowBudget
why not just run them?? I think if it was that big of a PIA I would just swap out the axles??
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
04-18-2011, 01:27 PM | #4 |
could b the studs had the wrong size knorl and it's just a matter of getting the studs with the proper sized knurl
only real way to find out is to remove one or two and measure and see if you can get replacement studs with proper size knurl for the hole
