04-16-2011, 06:13 PM | #1 |
Trick to removing clutch z bar?
I've got the rods unhooked, the nut, lockwasher and lock clip removed and can lift it out of the mount on the frame, but I can't pull it off the ball stud on the motor side. I can't lift it high enough to clear the bracket on the frame. Is there a trick to getting it out of there? '66 GMC 3/4 ton with V6 351 E.
04-16-2011, 06:42 PM | #2 |
Re: Trick to removing clutch z bar?
slide a jack under the trans and pick it up a bit until it clears the bracket and slide it out
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
04-16-2011, 10:29 PM | #3 |
That did it! Out in 30 seconds. Thanks bama.
