Old 04-16-2011, 08:05 PM   #1
Cbrown67
guys I need your oppinions
I Posted this in the electrical section but it didnt get many hits so here it is again. if you guys were buying a wiring harness would you get a mini fuse harness or a regular fuse harness?
Cbrown67 is offline   Reply With Quote
Old 04-16-2011, 08:12 PM   #2
bucketObolts
bucketObolts's Avatar
Re: guys I need your oppinions
If by regular, you mean regular sized spade fuses and not glasstubes, then I prefer the regular spades over minis. They're just easier to grab if you got a problem on the side of the road and you dont have pliers, but the mini block would take up less space. Not like you have much more going on under your dash than the fuse block though. I say regular. Thats what I bought at least
bucketObolts is offline   Reply With Quote
Old 04-16-2011, 08:18 PM   #3
tooter
tooter's Avatar
tooter is offline   Reply With Quote
Old 04-16-2011, 08:51 PM   #4
Cbrown67
Bucket did you get a whole new harness or just the fuse block
Old 04-16-2011, 09:01 PM   #5
bucketObolts
I bit the bullet and went with the Painless kit. Which is still in the box collecting dust
Old 04-16-2011, 09:27 PM   #6
71gmcburb
71gmcburb's Avatar
I just rewired my 66 econoline last summer and I used the large blade fuses for the block and a maxi fuse for the main supply and ignition. I have large fingers and always have a pair of plyers in the glovebox along with the spares also the large fuses are easer to find in an gas station
a wise man once said "There are only two real rules to life...
1 - Don't sweat the small stuff
2 - Everything is small stuff
71gmcburb is offline   Reply With Quote
Old 04-16-2011, 10:49 PM   #7
Cbrown67
thanks guys!
