Old 04-16-2011, 10:21 PM   #1
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
Underbed gas tank very slow to fill. Any ideas for venting, etc?
Way back before I restored Old Yeller I removed the cab gas tank and put a Blazer tank under the bed. Since I have a step side I routed the donor Blazer's fill neck out the rear of the left fender. IIRC, the tank came off a 71-72 body but was missing the gas cap. The 70 cap from my in cab tank didn't fit. When I bought a new cap I ordered a 71 cap but it didn't fit either. Ordering a 72 worked and has been on there ever since. (Who would have thought three different years would have three different gas caps?)
The only issue with it I've never resolved satisfactorily (this has been going on for years) is filling the tank is slower than pond water. I have to hold the nozzle sideways and at just the right angle and barely squeeze the handle to let the fuel tickle in. Putting the handle on the slowest setting usually is too fast and it will back flow out the inlet.
There are no restrictions in the fill line. There is one vent line that comes from the tank up to the fill neck. It has no restrictions in it. During the restoration I replaced the OEM tank with a poly tank. The poly tank has extra ports for hoses etc and I added an extra hose barb and hose and ran it up inside the fender next to the fill neck, put a bug screen over it and tied it off so it vents directly to air. I'm not at all satisfied with it being like that. It did help some but not much. It's possible the angle of the fill neck on Old Yeller is at just enough of a different angle than a Blazer to cause my problem. It doesn't look like it should be but I can't rule it out.
Reckon I'm going to have to live with it or is there hope for me?
Here's what it looked like before the resto and adding the second vent line.
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
Old 04-16-2011, 10:40 PM   #2
Old Yeller 1970
DON'T TREAD ON ME
Re: Underbed gas tank very slow to fill. Any ideas for venting, etc?
I realized after posting that the previous photos don't show the setup as currently installed, mainly because of the obvious arch in the fill line as it goes over the frame. Thinking that might be the problem I came up with two 1 1/2" 45 degree fittings that let it turn and make more of straight shot without kinking the hose. I just took the two photos below.
Old Yeller
Old 04-17-2011, 04:16 AM   #3
TrkEnvy
I was gonna say where the filler hose moves over that hump.. I would think that the direction change up is gonna slow the incoming fuel down and if its moving slower than whats coming out of the fuel nozzle its gonna back fill and your gonna have to pump slow. Did your fix help at all?? It still looks like the fuel has to travel uphill..
TrkEnvy is offline   Reply With Quote
Old 04-17-2011, 10:11 AM   #4
chevy72pu
chevy72pu's Avatar
I have the same problem with mine. It has a '90 sportside bed and the po had moved the filler neck from the front of the fender to the back and down to the blazer tank between the frame rails. It had the "hump" in it to. I tried new vent lines, new filler hose and even notched the frame rail to no avail. Finally cut a hole in the bed and fed the filler hose straight down to the tank using a "cool cap" opening. Still have trouble pumping it slow enough to keep the nozzle from shutting off. IMHO the intake tube on the blazer tank is too small to take the fuel any faster. I know this doesn't fix your problem, but at least I feel your pain. LOL
How 'Bout them Dawgs!
'10 Traverse LTZ
03 Silverado Z71 ext cab
99 Yamaha Grizzly 600
72 C10 350/350 sportside bed.
68 C30 flatbed. 350 4-speed.
"I've got a good memory, it's just short!"
chevy72pu is offline   Reply With Quote
Old 04-17-2011, 10:37 AM   #5
Old Yeller 1970
DON'T TREAD ON ME
I've wondered if that would resolve it at least now I know that's not a solution. I wonder if the Blazer guys have trouble with this.
Old Yeller
Old 04-17-2011, 10:40 AM   #6
Old Yeller 1970
DON'T TREAD ON ME
It's level with the truck now but it didn't really help. Making such a sharp turn may be the problem although there had to be a turn for it to get into the tank when it was on the Blazer.
Old Yeller
Old 04-17-2011, 08:38 PM   #7
chevy72pu
chevy72pu's Avatar
I wondered if they have trouble with it too. Maybe you could post this over on the Blazer forum and see what they say.
'10 Traverse LTZ
Old 04-17-2011, 09:10 PM   #8
Have you tried an extra vent on the opposite side of the tank to help the air escape during filling? I seem to remember most folks doing that and having a marine type or motorcycle vent stuck up in the passenger side fender wheel.
Old 04-17-2011, 09:24 PM   #9
bigguy69
dazed and confused
bigguy69's Avatar
i have the same problem with mine.the filler it is in the bed also. i would like to find a solution also.
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 04-18-2011, 08:19 AM   #10
Old Yeller 1970
DON'T TREAD ON ME
No, but that is a possibility. There is another place for a fitting on the passenger side of the tank. And I hadn't thought about a marine or motorcycle vent. I'll look into it.
Old Yeller
Old 04-18-2011, 09:00 AM   #11
The one
The one's Avatar
I just did this swap on my 1971 chevy 4x4 and have had no problems filling the tank. My tank came from Brothers Trucks (http://www.brotherstrucks.com/prodin...number=GTPDS72) and has two additional vents on the sides of the tank. I connected both of them with aluminum fuel line and ran a gas tube vent (http://www.motorcycle-superstore.com...With-Tube.aspx) inside the passenger side wheel well. Just make sure the vent is higher than your fuel filler and you should have no problems.I also connectd the vent line that runs up to the fuel filler neck.
The one is offline   Reply With Quote
Old 04-18-2011, 09:24 AM   #12
kevmic28
kevmic28's Avatar
It looks like you have a vent line capped off in the pics. This may be your problem. Also from what I can tell the vent that is capped close to the filler tube is the one that should go back to the filler tube. try reversing your connections.
I have 2 vent lines on my blazer tank. One goes back to the filler tube and another is just to a filter for venting.
1970 GMC truck
1988 Harley 1200 Sportster
kevmic28 is offline   Reply With Quote
Old 04-18-2011, 01:24 PM   #13
trz1000
FWIW, I have a 72 Jimmy and do not have the problem. The Jimmy fills better than my (now gone) 71 c-10 with the tank in the cab.
In Oregon you can't pump your own gas, apparently it's a way to create jobs but it really just slows down the fuel sale process. Anyway, the petroleum injection technicians always struggled filling the truck but have no trouble with the Jimmy.
trz1000 is offline   Reply With Quote
Old 04-18-2011, 02:04 PM   #14
kevmic28
kevmic28's Avatar
Only time I have issues with filling my truck is when I pull into one of the stations that has those damn rubber tips on the hoses, mostly in the bigger cities. They are so big that the nozzle will barely fit into the filler tube.
1970 GMC truck
Old 04-18-2011, 04:34 PM   #15
Lemield
Lemield's Avatar
I have a factory aux tank on my C20 and it fills REALLY REALLY slow too. Interested to know if you find a solution.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 04-18-2011, 05:03 PM   #16
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
I have a plastic tank and its vented out the wazzuu, still fills slow, I am going to try a metal tank and see if it makes any difference....
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 04-18-2011, 06:05 PM   #17
Old Yeller 1970
DON'T TREAD ON ME
Thanks for the link on the vent. I'll buy some and give them a try.
Where did you get the aluminum fuel line?
My poly tank looks exactly like that metal one. I wonder if it's possible that otherwise identical tanks but of different manufacture can affect the fill rate?
In the first set of photos it was capped but it's not now. The one that is closest to the filler is the one I have run up inside the fender with a bug screen tied over it. You can barely see it in the second set of photos.
Smitty
Good luck let us know how it turns out. FWIW, my original metal tank filled just as slow as my poly tank. If you buy the same tank from Brother's as The One did, it would be interesting to know if it cures your problem.
Old Yeller
Old 04-18-2011, 07:26 PM   #18
kevmic28
kevmic28's Avatar
The one next to the filler should be the one going back to the filler.
1970 GMC truck
Old 04-19-2011, 12:05 AM   #19
DaBigKahuna
DaBigKahuna's Avatar
How much does that tank hold?
DaBigKahuna is offline   Reply With Quote
Old 04-19-2011, 08:33 AM   #20
71meangreenc10
I have two of the vents on the plastic tank going up to the filler neck and the other side is vented to the charcoal canister. Do you think I need to take on of the vents off the filler and run it higher than the filler neck?
Thoughts.......
Smitty
71 C30 Wrecker
Old 04-19-2011, 11:39 PM   #21
OldSkool71
C/10 CLUB MEMBER
OldSkool71's Avatar
I have a metal tank and it is a pain to fill. Fills from inside the bed. Haven't had a chance to get under there and really check it out. Keep us posted. When I get under mine I will post some pics. And see where we are at.
-Ron-
OldSkool71 is offline   Reply With Quote
Old 04-20-2011, 12:22 AM   #22
RRR18
RRR18's Avatar
Mine is hella slow filling too. It gives me a chance to talk to a lotta people about how much they like the '67 to '72s at the gas stations though. Ha. This is only pic I have of the filler. Mine goes from the filler to a 90 and then straight to the tank. I have to check my vents.
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 04-20-2011, 12:54 AM   #23
Old Yeller 1970
DON'T TREAD ON ME
I just realized something. I don't know if this is causing all our trouble but if gas is able to get in the vent line and then sit there (which it could potentially do on mine) it will block the ability of the air trying to escape during fill up and make the tank slow to fill. I'm out of town on business but as soon as I get back, I'm going to take the vent lines loose at the tank and see if there's any gas sitting in there.
Old Yeller
Old 04-20-2011, 02:53 AM   #24
The one
The one's Avatar
I bought the fuel line from Speedway motors (http://www.speedwaymotors.com/Alumin...Line,1633.html) they have 1/4", 3/8" and 1/2" line I used the 3/8 inch fuel line and it worked out fine. The brothers tanks holds 21 gallons of gas.
Old 04-23-2011, 11:26 PM   #25
Old Yeller 1970
DON'T TREAD ON ME
Update: I pulled the two vent lines loose on my rig and neither had gas in them. I checked them out real well and air flows freely through either one. I'm going to say that ventilation is not my problem at this point.
After considering TrkEnvy's observation I rechecked the angle of the fill line and it was going uphill slightly. I took the filler line off and notched the side of the bed right above the fill line to allow it a better angle and reassembled it. I haven't been to the gas station yet. I may also lower the gas tank too. Right now it's tight up against the bottom of the frame but with some kind of shim it could be lowered 3/4" before the fill line contacts the top of the frame allowing an even better angle.
While I had the Blazer fuel inlet out, in the interests of science and making sure all my bases are covered, I took it to town and filled a gas can through the inlet. My thought was to make sure I didn't have any problems with it. I started with the fuel nozzle at the highest setting and gas immediately blew back out the inlet. I put it on the lowest setting and set the nozzle in the inlet like you normally would and it did fine. If I can get it to work like this on the truck I'll be tickled pink. Usually I have to hold the nozzle open so it barely trickles out the least amount of gas and I have to hold it side ways or gas spills out.
Old Yeller
