Old 04-17-2011, 06:30 AM   #1
gysgtc
My 67 c10 build
Almost done with the engine. Now I have to do the rest of the truck.
gysgtc is offline   Reply With Quote
Old 04-17-2011, 09:05 AM   #2
72chevy383
Re: My 67 c10 build
Nice, what do you have in the motor? As far as built wise?
72chevy383 is offline   Reply With Quote
Old 04-17-2011, 10:36 AM   #3
gysgtc
Re: My 67 c10 build
It is a 1970 350 2bolt main bored .030. 224 duration@.050 450int 460ex lift cam. GM Performance Vortec heads. Edelbrock 600 carb.
Old 05-22-2011, 12:27 PM   #4
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Re: My 67 c10 build
Can you give me the info for the idler pulley you have on your motor. I have a simular setup but mine is missing that assy. Do you have a part number? and also a belt number would help also
Trey
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 05-23-2011, 05:15 AM   #5
gysgtc
Re: My 67 c10 build
I will get the part numbers off of them for you today
Old 05-23-2011, 11:26 AM   #6
gysgtc
Re: My 67 c10 build
The part number GM 10129569. Summit sells them and the belt number is gm 88986814.
Old 05-23-2011, 06:49 PM   #7
chevytruckluver
Re: My 67 c10 build
Thanks for the help
Trey
72 Short Step
Old 11-26-2011, 04:39 PM   #8
gysgtc
Re: My 67 c10 build
Getting some work done
Old 11-30-2011, 07:37 AM   #9
gysgtc
Re: My 67 c10 build
Just installed poly tank
Old 12-11-2011, 01:53 PM   #10
chvyboy
chvyboy's Avatar
Re: My 67 c10 build
wow i love the serpentine belt on the motor looks clean. Long bed i assume?
My project: Spare change
http://67-72chevytrucks.com/vboard/s...=1#post5031992
chvyboy is offline   Reply With Quote
Old 12-11-2011, 07:29 PM   #11
gysgtc
Re: My 67 c10 build
At first didn't know if I was going to like the serpentine set up. Once I got it on the engine I think it looks good.
Old 12-12-2011, 01:16 AM   #12
chvyboy
chvyboy's Avatar
Re: My 67 c10 build
i like it. defiantly gives it a more modern look, plus im not the biggest fan of the original set up
Old 12-12-2011, 03:56 AM   #13
ZUBZ
ZUBZ's Avatar
Re: My 67 c10 build
Lovely build. I wish I can also strip mine down to the chassis and rebuild.
ZUBZ is offline   Reply With Quote
Old 01-28-2012, 04:48 PM   #14
oldschool18
oldschool18's Avatar
Re: My 67 c10 build
what spindles and rotors and calipers did you use
_________________________________
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Members Met......2003Silverado (Dave)
oldschool18 is offline   Reply With Quote
Old 01-29-2012, 06:48 AM   #15
gysgtc
Re: My 67 c10 build
I bought them from this place on ebay. http://myworld.ebay.com/tomsclassic/...id=p4340.l2559 You can send him a message and tell him if you want stock or drop spindles and 5 or 6 lug rotors. I used my original 67 ball joints and tie rod ends. (bought new ones) Wayne
