Old 04-17-2011, 09:18 AM   #1
fine69
fine69's Avatar
Front crossmember question. Spring pocket issue. HELP
Hey all.
I am working on board member 70cst's truck.
The Big block springs wont stay in place in the front crossmember. The front suspension has been changed to one out of a late 70's truck. With disc brakes.
I think the stamped nubs that the coil spring goes into is worn too far to hold the spring.
My question really is,
Is the actual crosssmember the same down to 67? I have another crossmember that is nice.
But i wanted others thoughts on it. Will the lower control arms from the later crossmember bolt right onto the 71 crossmember i currently have ?
Let me know fella's.
Or if your not sure what i am talking about let me know.
Thanks, Mike
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 04-17-2011, 10:11 PM   #2
fine69
fine69's Avatar
Re: Front crossmember question. Spring pocket issue. HELP
29 views and not one thought on it???
Board member #6
Old 04-17-2011, 10:52 PM   #3
70cst
70cst's Avatar
Hey...I'm signed on. I'll give you a few bumps.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 04-18-2011, 12:43 AM   #4
VA72C10
VA72C10
VA72C10's Avatar
not sure to be honest....never laid eyes on a 73-up crossmember to view the difference
Bump for you and maybe you could move this over to suspension forum if no hits here by tomorrow...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 04-18-2011, 07:11 AM   #5
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
good one Mike??
I know the later ones have the rubber control arm Bushings???? Another Good ?? would be can you convert from the solid shaft to the rubber bushings ??? then I could keep my pocked LCA and get the smoother ride???
Jeff
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 04-18-2011, 08:17 AM   #6
70cst
70cst's Avatar
Originally Posted by Hottrucks View Post
good one Mike??
Jeff
Thanks for the suggestion...I am open to whatever it takes to make the Circuit Rider safe and right.
Old 04-18-2011, 04:09 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
does it have drop springs or chopped springs by chance?
Old 04-18-2011, 07:05 PM   #8
70cst
70cst's Avatar
The springs are the factory spec'd front springs for a BB truck which are the same spring as a 3/4 T truck I do believe...
Old 04-18-2011, 07:46 PM   #9
70cst
70cst's Avatar
Earth to WES-Earth to Wes. Calling Wes.
Old 04-18-2011, 07:56 PM   #10
71 super
71 super's Avatar
try lolife and see what he says. I believe the crossmembers are the same if not identical. It would depend on the year of the swapped crossmember as some things changed around 81. I do know there is an extra hole that must be drilled in the frame to use the later crossmember. So the problem is in the upper portion of the member? If you are going to reuse the upper and lower control arms and the same drag link stuff the swap should not affect anything but the location for the brake hose attachment, as the 67 stuff exits to the rear while the 71 up stuff crosses over and exits to the front. Based on my own reasoning the swap should not be a problem with the exception of moving the brake line location. Hope this helps. Harold
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 04-18-2011, 08:07 PM   #11
70cst
70cst's Avatar
Thanks....any ideas are a big help as we ( Mike) tries to determine why the front springs are not seating correctly.
Old 04-19-2011, 02:01 AM   #12
70cst
70cst's Avatar
Other thoughts
Old 04-19-2011, 11:07 AM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by fine69 View Post
But i wanted others thoughts on it. Will the lower control arms from the later crossmember bolt right onto the 71 crossmember i currently have ?....
Mike- I have never done the swap on a 67-72, but my understanding is the later A-arms will work just fine. You might need to mod the brake lines a bit, but the rest should swap over.
To confirm, get Keith (Lolife99) or Scot (Scoti) in on this. Both those guys are have amazing memories on the topic.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-19-2011, 11:16 AM   #14
lolife99
67-72 parts collector,…
lolife99's Avatar
I've never done the 73-87 swap into an older chassis.
I always leave the original crossmember, itself.
The "D" stamp up in the spring pocket should be the same.
I don't understand how it's moving around?
Especially a full length spring.
Got any pics?
The 67-70 crossmembers have a brake line tab on the back side of the crossmember.
The 71-72 crossmembers have it on the front side.
73-87 have no tab.
The brake line connects thru a hole in the frame itself.
I see no reason you couldn't swap out the crossmember.
All the a-arms will interchange with the different year crossmember.
The only difference would be the 73-87 trucks had a slightly larger u-bolt.
A drill will fix that.
(9/16" if I remember correctly)
Keith
Convert to disc brakes.
Old 04-19-2011, 11:37 AM   #15
70cst
70cst's Avatar
Thanks for the follow up N2TRUX & lolife99...
I spoke with Mike this morning and the thought is maybe I was sent the wrong springs last fall. I bought these through ECE and Stan did not have the right set of springs in stock so he was able to find a set and had the springs sent to me. These springs are to be the same front spring as for a BB truck or C20 as they both take th same springs up front.
As Mike said these springs do not seem to be "seating" properly and I have noticed since I picked up the truck last Aug., it just didn't seem to steer/handle properly.
So for me this is a potential safety issue...we will eventually figure this out. Sometimes it's the fine tuning that can drive a person nuts. But we will get this resolved. Thanks again for all your input.
And for the record-Stan of ECE has been very helpful.
Old 04-19-2011, 11:56 AM   #16
lolife99
lolife99's Avatar
If you pull the spring,... take a picture up in the pocket.
Also take a picture of the spring itself.
I have never seen that area distorted.
I've had some extremely rusted trucks,... but there is nothing there that would wear the stamped steel of the crossmember.
I suspect it's the spring.
I still don't understand how it could move.
A BB spring or a stock length SB spring would require a spring compressor to install.
Even with the wheels off the ground,... you shouldn't be able to move it.
Keith
Old 04-19-2011, 01:07 PM   #17
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
WES to DeWayne-WES to DeWayne..lol I talked to Mike yesterday on the phone. I realy do believe the problem to be spring related. My hunch is and I spoke to Mike about it is that the spring was probably formed wrong. Either the "D" shape is too large or too small. Like lolife99 says,
Meaning the upper spring pocket. They only other problem it could be is the springs are lowering springs. I give that only a small chance, because Mike says that he can't get the spring to set in place, even with a crowbar.
My suggestion was to pull the springs and compare them with a set of originals he has setting around the shop. If they are different, then theres the answer. He can inspect the spring pocket once the springs are out. However like I said, I don't believe that to be the problem. The chances are pretty slim that one pocket would be distorted, let alone both. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 04-19-2011, 02:49 PM   #18
lolife99
lolife99's Avatar
Are you saying you can feel the front suspension moving around?
Has the front end been rebuilt?
(balljoints, tie rods, a-arm bushing, etc?)
Do you have newer shocks and a sway bar?
Keith
Old 04-19-2011, 03:04 PM   #19
70cst
70cst's Avatar
The front has been 100% rebuilt with new components as the rest of the truck. When I say the steering feels funny..I am saying it just doesn't feel tight and right. It's hard to explain.
Old 04-19-2011, 03:11 PM   #20
70cst
70cst's Avatar
Originally Posted by Classic Heartbeat View Post
WES to DeWayne-WES to DeWayne..lol I talked to Mike yesterday on the phone. I realy do believe the problem to be spring related. My hunch is and I spoke to Mike about it is that the spring was probably formed wrong. Either the "D" shape is too large or too small. Like lolife99 says, Meaning the upper spring pocket. They only other problem it could be is the springs are lowering springs. I give that only a small chance, because Mike says that he can't get the spring to set in place, even with a crowbar.
WES....
My thinking is that the wrong front springs were shipped. There can only be so many possibilities to why these springs seem not to fit properly.
Again thanks all for your input.
Old 04-19-2011, 11:08 PM   #21
fine69
fine69's Avatar
I will get it figured out, and let everyone know.
Board member #6
Old 04-23-2011, 12:36 AM   #22
70cst
70cst's Avatar
Next Monday fine 69 will have the Circuit Rider up on the lift and we will find out what is causing the front spring problems...
