speaker locations
What do you guys use to cut the holes in the door and kick panel for speakers?
'85 k10 long bed, 6" lift. 35" tires. 350, Edelbrock intake/carb, headers, dual exhaust. Automatic. |
Re: speaker locations
A cut off wheel or an air saw would be fine.
Oh okay, so you just drew the circle, and followed the line. Gotcha.
I use the speaker to trace an outline on the door, drill a pilot hole and use an air chisel to make the cut. If you use a sharp chisel and work slow, the hole will turn out nicely and not need too much cleaning up. Before I install the speaker, I use a little bit of foam weatherstripping before mounting the speaker. As far as the screws, I use regular self-tapping sheet metal screws.
Jeremy I have done so much, for so long, with so little, I can do anything with nothing! 1984 GMC Sierra Classic-1/2 ton-SWB (R.I.P.) 1986 GMC Suburban 3/4 ton 4x4 2014 GMC Sierra LTZ Z-71 Crew SWB |
yeller
Why cut the doors for speakers...when you can put them in the cab corner? See the link in my signature.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
I'm going to make brackets like that, but that hold 2 6.5" speakers. I already have the speakers. I was just toying with the idea of speakers in the doors.
