What to do about my drip rail :(
So this last year of rain and neglect on my part has taken it's toll on my trucks drip rail. Prior to the paint job (which is now about 4 years old), I had removed the rust on the rail and applied new leveling sealer. Now it has began to rust rapidly and I'm trying to decide what to do about it..
1) Sand it down and repair it myself (rattle can). 2) Get some quotes from the local body shops to repair it 3) Remove the drip rail all together (I'm not sure how involved that would be but likely the most expensive option). I love my truck dearly, but that drip rail makes me ![]() ![]() ![]()
___________ Greubin '71 C20 custom - GM Crate 350CI/290HP, BTO 700R4 level II, Qjet, and HEI ![]() |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: What to do about my drip rail :(
Is that rust under the drip rail also on the drivers side above the windshield?
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Yup
Id say try it yourself and buy a decent paint gun and go for it. Check out the autobody section on this site, they talk a lot about rust prevention and what works best. Or you can check out the forum at www.autobodystore.com also they have some good info. Either way make sure you get it all down to bare metal first.
1969 Chevy c20(Miss Hackjob) Last edited by treveiger; 04-17-2011 at 04:39 PM. |
#5 | |
Not sure but i think there may also be a drip rail repair kit avalable somewhere too.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
![]() Join Date: Aug 2003
Greubin, go to www.rustbullet.com and watch the videos. I've used RustBullet before and (I'm NOT getting paid for this) it is without doubt THE BEST system for Rust prevention and it stops rust COLD, PERIOD.
Watch the test videos and it'll explain everything. I'm using it right now on my Truck. I had some rust under the Battery tray and on the inner fender, very common on our trucks. I couldn't afford a new inner fender, so I researched the H**L outta everything on the market and RustBullet was my choice. Glad I bought it and the results are fantastic. You can Brush it on, Spray it on, Sand it down, shot primer over it and then paint over that. Look around at all the others, but when you're ready to get serious, get RustBullet. Check this out: http://www.rustbullet.com/testimonial.asp?id=4
1968 SWB. GMPP 350/350 Turbo Trans, Edelbrock Performer & Carb. Hedman Hedders, Hooker Aerochambers Mufflers. Tuff Stuff Alternators. Remember, no matter where you go, There you are. Gary Last edited by 96blazr; 04-19-2011 at 08:09 AM. Reason: more info |
![]() Join Date: Jan 2008
I'd find a donor top and replace the top. I've done this a few times, and IMO it's the easiest way.
If you have any threads or step by steps with pictures that would be some great info! I passed on a truck i really wanted because the roof rust, and price.
I don't have any pics, but a friend of mine might. I'll see if I can get any. If you decide to go this way, let me know, and I will point you in the right direction. By the way, where are you located?
