Old 04-17-2011, 04:39 PM   #1
profe56
Rear Sway Bar and Shock Absorbers Brackets
I'm working on a suburban 94 rear end that I want to swap at my C10 69 and I took away some brackets except for the bracket that holds the rear sway bar and the shock absorbers, I want to know if one the members also swap the sway bar and if the shock absorbers can be relocated originally C10 has both in front of the rear end and suburbans has one in front and one behind.
how can the track bar can be relocated or sway bar works as the track bar?
Thank you
Uploaded with ImageShack.us
profe56 is offline   Reply With Quote
Old 04-18-2011, 09:42 AM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Rear Sway Bar and Shock Absorbers Brackets
ttt
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 04-18-2011, 02:25 PM   #3
profe56
still ttt.........
Old 04-18-2011, 04:21 PM   #4
brad_man_72
the boat guy
brad_man_72's Avatar
sway bar won't work as a track bar! I assume you'd have to find a way to mount the rear sway bar in front of the rear axle. Rear sway bar will cause more oversteer.
brad_man_72 is offline   Reply With Quote
Old 04-18-2011, 10:01 PM   #5
brad_man_72
the boat guy
I'd get an adjustable track bar and mounts.
if coil rear I'd get the mount kit that has the control arm pads and use the stock c-10 shock mounts maybe flipped if lowered
