Old 03-25-2003, 07:56 AM   #1
MSL
MSL's Avatar
Cool Newbie.
Hello im new to the board I just recently purchased a 1978 chevy short bed custom deluxe 2wd it has a small block 350 th350. I have been searching all over for messageboards to find a palce to ask questions and this one looks really good and a real tight group here.
I found my truck on a car lot the guy wanted $2000 for it and i picked it up for $1700. the truck is in pretty good shape. I will have to get some pics of her up to show you the conditon. i have pulled the manifold and carb off it was to much for the engine. it originally had a edlebrock streetmaster manifold with a holley carb im not sure what the cfm is for the carb but when i would get up on it the valves rattled and it was terrible. so i put a edlebrock 2101 non egr performer with a edelbrock 650cfm and it runs alot better. I am having some problems with the engine missing at a idle and its got me stumped it runs smooth as can be when i drive it. if you have any ideas what could be the problem im all eyes.lol Oh i have timed the engine to 8degress BTC.
Also the streetmaster manifold has the hole in the front for the old oil tube. I want to sell it but need to know how much its possibly worth.
Well i hope to be on here alot and hope you guiys can help me out. i will be restoring my truck over time as much as i can afford and do.
Thanks MSL
MSL is offline   Reply With Quote
Old 03-25-2003, 09:32 AM   #2
BigRed
Welcome to the board! You definitely have found the most helpful board online for 73-87 trucks! Glad to see another 70s guy join.
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 03-25-2003, 09:39 AM   #3
brad2
I don't have an answer but I bet you will get some input before long. Welcome from Oklahoma.
brad2 is offline   Reply With Quote
Old 03-25-2003, 10:44 AM   #4
Low87
been here longer than Liz
Low87's Avatar
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 03-25-2003, 11:47 AM   #5
78SilveradoSWB
78SilveradoSWB's Avatar
Thumbs up
Welcome To The Board, MSL!
Mitch
1978 Chevrolet Silverado C 10
454 BB, TH400
78SilveradoSWB is offline   Reply With Quote
Old 03-25-2003, 12:02 PM   #6
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
Welcome!!
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 03-25-2003, 01:59 PM   #7
bagged81
Signals in the bumper.
bagged81's Avatar
Welcome!
Jeff C.
1981 Chevrolet Silverado - Under major construction...again. link
1962 Chevrolet Impala 4D Sedan moredoorclassics.com
1936 Ford Pickup - Frame-off in progress link
1979 Chevrolet Camper Special Flatbed link
bagged81 is offline   Reply With Quote
Old 03-25-2003, 03:38 PM   #8
Prerunner1982
Prerunner1982's Avatar
welcome....
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 03-25-2003, 04:18 PM   #9
rage'nrat638
rage'nrat638's Avatar
Thumbs up we need sound clips
well is this got a dead miss.or just some popping out the exhaust??????the whole truck shakes?????kind of sounds like a vacuum leak if not a dead miss...could be a bad vacuum mod. on trans. hows it shift??? disconnect vac line and see if trans fluid runs out..pulling straws here need more info .will be glad to help.
o by the way welcome.,...MARK
rage'nrat638 is offline   Reply With Quote
Old 03-25-2003, 05:25 PM   #10
Blue Beard
Blue Beard's Avatar
Welcome from Washington State..............
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 03-25-2003, 06:23 PM   #11
MSL
MSL's Avatar
Re: we need sound clips
Thanks for the welcomes glad to be apart of the community.
Ok as for the miss its like it stumbles at a idle but picks back up. when it misses it skips from smooth then its like a thud type miss i feel it in the cab it doesnt shake and no popping out of the exhaust. I might lean towards the vacum mod. the truck shifts a little rough not bad its just a little bit. No trans fluid from line in fact it fell off one time and i had to put it back on so no fluid. I have HEI dist. i changed the plugs about a month ago and the plugs from cylinder 3 and 5 didnt look as good as all the rest and thats where im feeling the miss is on the drivers side. number 3 plug had some oil on the threads and 5 had some build up. all the rest where fine.
Old 03-25-2003, 06:47 PM   #12
Trick76
Living la vida broka
Trick76's Avatar
Welcome
Derek
1976 C10 Longbed lowered 5/7, hot 355/TH350. ~ SOLD
1974 C10 Shortbed Stepside 350/Saginaw ~ SOLD
1984 C10 Longbed 6.2l diesel 700r4. ~SOLD
1985 GMC C20 350 700r4, ~under the knife
Trick76 is offline   Reply With Quote
Old 03-25-2003, 06:49 PM   #13
CRRoy71
Chris
'92 ext. cab s/b 4.3L "Sparky"
'04 crew cab 2500 4x4 6.0L
CRRoy71 is offline   Reply With Quote
Old 03-25-2003, 07:28 PM   #14
rage'nrat638
Lightbulb cyl leak down
well the only thing to do then is a cyl leak down test to check valve seal and rings---- if rings,,, may have blow by in air filter if you have the positive crank case vent still hooked to air filter???
the leak down will point you to engine or the ign.ststem,,,still my be vac problem...you can spray carb cleaner--w-d 40--around intake and carb base...if leaking should idle-up do with engine cool as possible and be careful dont start a fire keep extingusher
near by(i know its spelled wrong) let me know
Old 03-25-2003, 08:26 PM   #15
apstguy
LED King
apstguy's Avatar
Welcome!
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 03-25-2003, 08:53 PM   #16
CT-Truckster
CT-Truckster's Avatar
welcome aboard.
CT-Truckster is offline   Reply With Quote
Old 03-25-2003, 09:46 PM   #17
82BlackBeast
Welcome to the board!!
Matt
'82 Chevy SWB
82BlackBeast is offline   Reply With Quote
Old 03-25-2003, 10:06 PM   #18
bigblock73
yeller
bigblock73's Avatar
Welcome bro!
-Jeff
bigblock73 is offline   Reply With Quote
Old 03-25-2003, 10:12 PM   #19
BaggedC10
Under construction!
BaggedC10's Avatar
Welcome.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 03-26-2003, 12:14 AM   #20
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Welcome
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 03-26-2003, 01:26 AM   #21
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
More newbies!!
Welcome aboard.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 03-26-2003, 02:03 AM   #22
MSL
MSL's Avatar
Re: cyl leak down
Thanks for the welcome.
I will have to try those things out. i dont have a fire exting.So is there something no flamable i could use.lol I dont have the stock air cleaner i have a push in breather in one valve cover and the pcv comes of the front of the carb to the passenger side valve cover. is still have stock valve covers and plan to change them.. Also what plugs are you guys running in your trucks.?
Old 03-26-2003, 02:28 PM   #23
mckpaul
mckpaul's Avatar
Howdy from Texas!
Paul
1984 Chevy C-10
*LWB/305*
mckpaul is offline   Reply With Quote
