04-17-2011, 07:48 PM | #1 |
Quick dash question.
So on my '63 the PO put wood grain on the glovebox, ash tray, and heater control nobs. It looks as though it was glued on and doesn't come off well. I was talking with the painter and he had no idea how to get it off.
So that brings me to my question. Are there replacement glove box doors, heater control covers, and ashtrays out there? I was looking through LMC but didn't see anything as with other catalogs. Any input would greatly be appreciated. Thanks. |
04-17-2011, 08:21 PM | #2 |
Re: Quick dash question.
If it was glued to the paint a little paint stripper in behind it will loosen it up and it should come right off with a little time and effort. When done just finish stripping and repaint.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
04-17-2011, 08:42 PM | #3 |
also, if glued (ewwww) there is a product called "goo gone" available at home depot that might help. Might now, but might be worth a try.
04-17-2011, 08:47 PM | #4 |
1961 crewcab
no on the repros, would have to find some used...
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
04-18-2011, 12:19 AM | #5 |
You could try a heat gun to soften the glue enough to peel it off, then use goo gone to remove the rest of the residue. If it's only on metal you could try sanding it off, go slow and use a finer grit than you think and lots of extra elbow grease not to mess up the metal under too much.
Posted via Mobile Device |
04-18-2011, 08:30 AM | #6 |
Well these are the best pictures I have right now. it feels as though it was gorilla or super glued on. I was working on getting the wood off around the radio and barely any came off with the tricks described. it looks disgusting and doesn't want to come off. Now where do I go?
04-18-2011, 08:49 AM | #7 |
Double 6's
man your making me think twice about the airbrush woodgrain I had done... lol
Sorry about the words....cant figure out how to get that picture back down....my painter knows me well and played a little joke
Street Glidin! 1966 LWB Custom Cab (sold) 1982 Short Fleet (under the knife) 1998 S10 2wd Fleet 2007 Chevy Silverado Crew 2007 Harley Davidson Street Glide Last edited by badblu97; 04-18-2011 at 08:51 AM. |
04-18-2011, 09:02 AM | #8 | |
04-18-2011, 09:03 AM | #9 | |
I like that! mainly because it isn't protruding from the metal and can be repainted as needed. Mine looks like that cheap boarding they would put up in old campers or trailers. |
04-18-2011, 09:28 AM | #10 |
worse case......take the ash tray, heater face and glove box door off and sand blast them, prime and repaint them. thats what i had to do to my ash tray and it came out like new.
The price of cool aint cheap. |
04-18-2011, 10:18 AM | #11 |
Senior Enthusiast
Another possible solution for breaking the bond is lighter fluid. 3M markets 8984 General Purpose Adhesive Cleaner, and near as I can tell its straight lighter fluid. I was introduced to it about 20 years ago as the solution to removing pin striping tape from car bodies. When all else fails this does release every adhesive I’ve encountered. Obviously it's an extreme fire hazard so be careful if you decide to try it.
http://www.toolrage.com/prodview.asp?sku=3M-8984 |
04-18-2011, 06:02 PM | #12 |
[attach][/attach]
04-19-2011, 02:49 AM | #13 |
Tuckers truck parts has used stuff but I don't know what their inventory. I have also gotten used parts from Dan's Classics in Portland, Oregon.
http://67-72chevytrucks.com/vboard/s...d.php?t=456437 |
