Old 04-17-2011, 10:40 PM   #1
zackary027
zackary027's Avatar
Flooding when hot
i have a brand new edelbrock 600 electric choke, and a manual fuel pump with only two lines in and out, when my truck gets hot and i turn off for a few minutes when i go to crank back the carb is flooded. i was told to get a fuel pump with 3 ports one for return will this help?
zackary027 is offline   Reply With Quote
Old 04-17-2011, 10:46 PM   #2
Your41Plague12
Your41Plague12's Avatar
Re: Flooding when hot
Yes it will. The excess fuel that the carb can't put to the motor will go back to the gas tank. That might solve your problem. I'd also put a pressure regulator in, IMO.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 04-17-2011, 11:33 PM   #3
GMC Guy
GMC Guy's Avatar
i have a edelbrock fuel pump on mine, with only 2 ports. i have a similiar problem starting the truck when it's hot. maybe that's my problem, and not the starter.
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 04-18-2011, 09:27 AM   #4
McSwine
McSwine's Avatar
A spacer between the carb/manifold might help, too.
McSwine is offline   Reply With Quote
Old 04-18-2011, 09:57 AM   #5
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
engine heat finds its way to the carb base and it boils the gas in it and it floods over into the intake...a simple fix is a carb base gasket ot 1" spacer that will fix it.....
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 04-18-2011, 01:45 PM   #6
Rons86
Rons86's Avatar
Amen to the spacer. Had the same problem with mine and a spacer made a huge difference.
Rons86 is offline   Reply With Quote
Old 04-18-2011, 02:58 PM   #7
GMC Guy
GMC Guy's Avatar
i'm running a two inch phenolic spacer right now, solved the quick running around town starting back up problem. but the starter sounds like it drags if i try to start the truck after jamming down the highway.
zackary027, definitely add a 1" spacer though, it may be as simple a fix as that
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 04-18-2011, 06:46 PM   #8
Shyguy
Junior Member
Shyguy's Avatar
The starter sounding like it is dragging when trying to start hot is possibly from heat soak if you have headers.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 04-18-2011, 08:28 PM   #9
kody
mine was doing the same thing.had to set the floats,now runs great.
kody is offline   Reply With Quote
Old 04-19-2011, 06:30 AM   #10
Hottrucks
Hottrucks's Avatar
^^^^^ I AGREE 100% good call header wrap or a mini starter will help
Old 04-19-2011, 03:02 PM   #11
GMC Guy
GMC Guy's Avatar
i've been looking into a mini starter, will these two work?
http://cgi.ebay.com/ebaymotors/SBC-B...Q5fAccessories
http://www.db-starter-alternator.com...0-shi0032.aspx
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 04-19-2011, 05:56 PM   #12
tucsonjwt
Those starters are the same design as the GM high torque mini starters - rectangular square mounting block and small motor. The genuine GM starters are more expensive, but I don't know if they are better. I have a GM high torque mini starter in my 83 BB, and I think it helped hot start issue. I think the GM p/n was 12361146, but be sure to check your application. Cost is like $200+ now at a lot of places. The only think I don't like is that the rectangular mounting block leaves an small open space in the top of the mounting surface of the round opening for the original starter motor. I think I will put a piece of sheet metal over that someday. Here is a picture of the GM OEM starter.
http://www.gmpartsdirect.com/results.cfm
I think the phenolic spacer under the carburetor will help, but I don't want one on my truck because then all of the connections to the original Qjet I have will be off (e.g. air cleaner snorkel tube to exhaust manifold, all linkages, etc.) I had one on my 73 BB and it was a cobbled up mess - but did seem to help hot starts. I just floor the accelerator and keep it down when starting hot and it always starts - not efficient but effective.
tucsonjwt is offline   Reply With Quote
Old 04-30-2011, 10:30 PM   #13
zackary027
zackary027's Avatar
spacer solved my flooding issue
