04-17-2011, 10:41 PM | #1 |
Eat, Sleep, Drive a Chevy
Hooker headers and angle spark plugs?
I was just looking at Summit for some headers and saw where the Hooker part number used for our trucks says wont work for angle plug heads.
I am not going to change the heads but I want a good quality header. Is anyone else running angle plugs on thier trucks? What have you found that works well? Thanks in advance
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
04-17-2011, 10:45 PM | #2 |
At the body shop.
Re: Hooker headers and angle spark plugs?
My dougs pn# d-310c work on angle plug dart 200cc iron eagle.
Although on a 73 id guess they would cross over? |
04-17-2011, 11:02 PM | #3 | |
Do the dart heads have "D" shaped exhaust ports too? Where did you buy your Doug's?
04-18-2011, 07:12 AM | #4 |
I run Hooker Super Comps with Victor Jr angle plug heads with no problems at all! I can change my plugs in 10 minutes or so, and no burnt wires. I also run good MSD wires.
04-18-2011, 10:03 AM | #5 |
Have an older set on my Trick Flows, not sure what model they are. Where would the number be?
04-18-2011, 03:52 PM | #6 |
Good question, I dont think I have ever seen the part nubers on the headers. Do you have any pics of yours?
04-18-2011, 03:55 PM | #7 | |
I'm guessing the tubes are diffrent on the super comps, are those the racing version from Hooker?
04-18-2011, 05:19 PM | #8 |
I'm not sure, They have a 3" collector with a flange, but they are 1-3/4 tubes.
04-18-2011, 09:12 PM | #9 |
DON'T TREAD ON ME
I have Hooker Headers and they clear my angle plugs OK. I think mine are the Competition (not 100% sure) Headers. They're 1 5/8 primaries with 2 1/2 collectors. They also clear the clutch linkage for my manual tranny too. The only plug that's a slight issue is the spark plug boot on cylinder 5 comes very close to the header pipe. Just to be safe I have a ceramic sleeve over it and have had no issues.
Old Yeller |
04-19-2011, 12:28 AM | #10 | |
04-19-2011, 09:32 AM | #11 |
DON'T TREAD ON ME
I should have the receipt showing exactly what I bought in a file at home. I'm out on a business trip the rest of today. I'll look it up when I get home tomorrow.
Old Yeller |
04-19-2011, 09:47 AM | #12 |
Old Yeller and I must have the same ones, they came on my truck. I put a sleeve on the #5 plug. The only prob I have is needing to trim the flange a tad for the #1, 7 2 and 8 plugs, the socket hits the flange when putting in plugs. Maybe a cheaper/thinner spark plug socket would work too.
04-19-2011, 10:04 AM | #13 |
DON'T TREAD ON ME
JMac11, Do you still use the stock heads/plugs? Mine are aftermarket heads that use the smaller socket size so I don't have any clearance issues with the flange.
Old Yeller |
04-19-2011, 11:01 AM | #14 |
Trick Flows that use that Crazy AC5 plug I think is the number.
04-24-2011, 01:06 PM | #15 |
At the body shop.
More of a square port. Summit racing and 0 clearance issues. with plugs or ground clearance
04-24-2011, 01:19 PM | #16 | |
Based on what I have seen here I did go ahead and ordered the 2452-1 Hookers. I can see no reason for any clearance issues for he angled plugs, from past experience with angled plugs it made things easier. wish me a little luck here. Thanks for all your input guys
04-24-2011, 02:48 PM | #17 |
let me know how it goes I have a brodix trackI headed 355 with zero miles.. that would be sweat in my truck
