Old 04-17-2011, 11:39 PM   #1
sduckworth13
sduckworth13's Avatar
1967 GMC power steering conversion
I have a 1967 GMC 3/4 ton with 8 lug drum brakes, non power assisted brakes, and manual steering. I'm swapping the complete 5 lug disc/ drum suspension minus the crossmember and leaf springs from a 1974 Chevy 1/2 ton truck. I also have the power steering gear box from the 1974 Chevy 1/2 ton truck. I have the frame dimple worked out already.
My question is, do I use the 1974 Chevy 1/2 ton PS pump, hoses, and ps engine mounting bracket. Can I use the ps engine mounting bracket from a 1974 Chevy truck without modifying it and without modifying my set up which is the alternator on the left side. I believe I need a three groove pulley from a big block, not real sure on that part either.
Thanks,
Scott
sduckworth13 is offline   Reply With Quote
Old 04-18-2011, 09:50 AM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: 1967 GMC power steering conversion
ttt
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 04-18-2011, 02:00 PM   #3
long69
from the best i can remember:
for the box you can use anything into the '80's. its just a matter of what hose your going to use. i think there are at least 3 different styles maybe more. all the variations in hose conversions are available.there are differences in the rag joint also.
here's my conversion story- i chose a quick ratio box from the late '70's that was supposed to use the same hoses the same everything. not so. 67-72 use inverse flair fittings, this box used something else. maybe "o" rings? this box also had standard threads. i hear that some went metric.i found the adapters to use. once i got everything together for the swap most stuff just bolted in. other things needed fitting. nothing major at all. i did my swap on the cheap so i had to trust the zbay sellers description of the parts. for the hoses and other easy to obtain items i just bought new.
long69 is offline   Reply With Quote
Old 04-21-2011, 11:41 AM   #4
John Fabris
TOTY 2006
John Fabris's Avatar
no on using the 74 ps pump brackets, as I believe the 74 and later engines use the long next water pump and this puts the belts closer to the rad. So if you current engine has a short water pump, you will need to find the correct brackets from a short pump set up.
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
