Old 04-18-2011, 01:52 AM   #1
sanford66
sanford66's Avatar
Odometer running backwards!
I was driving my 68 c-10 down the highway the other day and noticed my odometer was going backwards, in other words, instead of gaining mileage its actually dropping mileage on the odometer! Has anyone else ever had this happen? What would make it do this? Joseph
1970 Chevelle Nomad station wagon
1966 C-10 lwb,250-six,granny 4speed
1966 C-10 lwb,factory A/C,Custom Cab
1954 Delray 2-door sedan [rat rod project]
sanford66 is offline   Reply With Quote
Old 04-18-2011, 02:34 AM   #2
mustardjimmy71
toys'r'us
mustardjimmy71's Avatar
Re: Odometer running backwards!
not by accident i havent...
71 jimmy bone stock 350 sm465 33x12.5 rallies
79 caprice landau full load crate350 th350 lowered 20"wires
00 f150 reg cab sb 4x4 5.4L
mustardjimmy71 is offline   Reply With Quote
Old 04-18-2011, 03:22 AM   #3
Jeffs70
Jeffs70's Avatar
never had it happen by accident lol. just fix it before or if you plan on selling it LOL
Jeffs70 is offline   Reply With Quote
Old 04-18-2011, 06:37 AM   #4
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I saw it in the movie "Christine!"
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 04-18-2011, 06:55 AM   #5
ricks71pu
ricks71pu's Avatar
look in the rear veiw, are you getting younger?
In the words of my favorite poet, singer/songwriter (Paul Thorn):"What ever you believe, you might be wrong"
ricks71pu is offline   Reply With Quote
Old 04-18-2011, 01:11 PM   #6
sanford66
sanford66's Avatar
HAHA!!!...I wish i was! So...doe's anyone have any technical thoughts on this? Joseph
Old 04-18-2011, 01:47 PM   #7
brad_man_72
the boat guy
brad_man_72's Avatar
unless your rear end is in upside down and you have to drive with the trans in reverse I have no clue.
brad_man_72 is offline   Reply With Quote
Old 04-18-2011, 02:03 PM   #8
Gobbles
Gobbles's Avatar
Maybe its counting down the miles left!
Trevor
"You already said spite"
Gobbles is offline   Reply With Quote
Old 04-18-2011, 02:13 PM   #9
gcburdic
Restoration Virgin!
gcburdic's Avatar
Boy the guy in Ferris Bueller's day off could of used this
Sounds like something with the speedo itself....may want to take apartand look around
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 04-18-2011, 02:15 PM   #10
HeavyD
HeavyD's Avatar
Aha that's what I was going to say. Should be fine just don't make the truck angry
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 04-18-2011, 02:16 PM   #11
yote1234
yote1234's Avatar
trans gear in backwards?
1971 K5 CST Blazer
1965 Chevelle Malibu 283 (sadly sold)
1968 Camaro 327
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline   Reply With Quote
Old 04-18-2011, 04:01 PM   #12
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if the speedo is working, I don't see how it could be happening.
As far as the fix it before you selll it comment, there is nothing at all illegal about resetting the odometer. The illegal part is when you try to profit from it. When I got my truck titled for the first time, I flat out told them I set it to 00,000.0 miles.
Old 04-18-2011, 04:09 PM   #13
brad_man_72
the boat guy
after 10 years or 100k miles I think you can do what you want with your odometer in mo. I always set mine to 0 when I do an engine rebuild.
Old 04-18-2011, 07:22 PM   #14
68gmsee
Active Member
68gmsee's Avatar
Did it just start doing it? Did you do any work in the speedometer area before it started acting up?
There's no way to put the transmission drive and driven gear in backwards. The teeth wouldn't mesh properly as they are slanted to engage with each other.
Check if there's some sort of intermediate gearing device someone may have installed in there. If there isn't than it has to be in the odometer itself.
68gmsee is offline   Reply With Quote
Old 04-18-2011, 09:05 PM   #15
19seventeeCustom
LMAO! everybody is kinda cracking jokes at the subject, believe it or not my old 94z28 done the exact same thing!! At first I noticed the odometer not working every once in a while, and outta the blue I happen to see it running BACKWARDS!!!
it done that for the next year or so that I drove it lol I think I ended up putting 2 or 3k miles backwards ....haha
19seventeeCustom is offline   Reply With Quote
Old 04-18-2011, 10:40 PM   #16
70C10Toejam
Hellasick
70C10Toejam's Avatar
Iowa's basically the same. 10 years and older exceeds mechanical limit. Even the newer ones that show the 100,000 it isn't needed after 10 years.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
Old 04-18-2011, 11:15 PM   #17
trapperjack
trapperjack's Avatar
Is the paint looking better? Dents going away? Rust disappearing? Can I send you mine, and have you run it down to about 10? I could have a new truck. You'll be a millionaire.
1962 Chevy K10 factory 4x4 stepside longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=494632
1967 Chevy 3/4 ton 4x4 long bed (Henrietta) traded
1968 Chevy 1/2 ton panel wagon, V8 and powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=483345
1978 Ford F250, beater stepside
2008 Jeep Wrangler 4 Door
2010 Chevy 4x4 plain jane work truck
trapperjack is offline   Reply With Quote
Old 04-19-2011, 10:25 AM   #18
bollybib
bollybib's Avatar
ok, i'll bite and offer a theory,
the drive cable breaks somewhere inside the cable housing, the broken ends shift and slightly overlap one another, and with enough friction between them produce a counter-rotation beyond the break
have at it...
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 04-19-2011, 10:50 AM   #19
Stocker
20' Daredevil (Ret)
Stocker's Avatar
If the speedometer needle is working correctly, the cable is working correctly. The problem must be the odometer itself.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 04-19-2011, 11:01 AM   #20
69sixpackbee
Put in in "D" not "R"
69sixpackbee is offline   Reply With Quote
Old 04-19-2011, 11:08 AM   #21
DeputyDan
Crazy! In Missouri when I went to title my truck they made me submit a regular inspection as well as an odometer inspection. Each cost me $10 at a local mechanic. The mechanic had to fill out a sheet that said the miles were correct, the odometer had not been tampered with, and that the VIN#'s were all matching. They told me I had to do this because I bought the truck in IL and live in MO. So, I guess unless your planning on selling it out of state your probably ok.
DeputyDan is offline   Reply With Quote
Old 04-19-2011, 11:23 AM   #22
DaSchlange
DaSchlange's Avatar
Of course I do not know this, but if the odometer is operated by a small electric motor, the ground and positive wires could be switched around causing it to spin the opposite direction.
DaSchlange is offline   Reply With Quote
Old 04-19-2011, 02:04 PM   #23
sanford66
sanford66's Avatar
Thanks for all the replys guys. I wish the rust, dents etc...was disappearing as i drove it, but unfortunatly this isn't the movies!! HAHA! I'm going to go with you guys and point the finger of blame at the odometer because the speedometer works as it should, even though its about 10mph off. I have had many older cars and trucks over the years and this is the only time i have ever seen or heard of this. Thanks for the opinions and wise cracks, you guys are always good for a laugh! Joseph
