Old 03-25-2003, 10:29 AM   #1
Narkoleptik
69 GMC LWB FLEET
Narkoleptik's Avatar
A Question About A Problem My GMC Is Having...
Ok, for the last couple of days, my truck has been having a rough time taking off at the lights... It used to be that hitting the gas meant that the truck would immediately leave the line and run smoothly... Now, when I step on the gas, (not hard mind you) it takes a few seconds for it to speed up to what it used to be like. It kinda seems to struggle when started at an upward angle (IE a light on an overpass) Almost like it is wanting to shut itself off... MY father says it might be a problem with the fuel pump and I haven't been able to replace it with a new one, was wonder what most of you thought as well? Perhaps Tranny problems? (HOPE NOT)
Thanks in advance for your input.
TUCSON, AZ
Narkoleptik is offline   Reply With Quote
Old 03-25-2003, 10:32 AM   #2
nightmare
nightmare's Avatar
doesn't sound like a tranny problem to me. sounds like it might be the fuel pump, but could be the filter too.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 03-25-2003, 10:35 AM   #3
Randy70C-10
Randy70C-10's Avatar
Doesn't sound like the tranny. Could be a number of things though. How old are your spark plugs? A fouled plug will definately kill your take-off. Do you have a mechanical pump? Usually a fuel pump either works or it doesn't.
Randy70C-10 is offline   Reply With Quote
Old 03-25-2003, 10:44 AM   #4
Randy70C-10
Yeah, filter could be a good thing to check to, or maybe there is dirt or a piece of rust clogging a jet. Also, check all of your vacuum lines.
Old 03-25-2003, 11:43 AM   #5
Mongo
YES_____NO
Mongo's Avatar
one other thing to check is the gasket under the carb if you have a small leak in the seal it will kill your take off. If the leak in the seal gets too large your truck will run like $hit and wont idle worth a damn. get some carb cleaner and while the truck is running spray it around the base of the carb if the idle changes you have a gaasket leak. also spray it around all vaccuum lines check for any vaccuum leaks.
I went through two fule pumps three fule fliters and half a box of band-aids before I found this leak.
good luck
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown
Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984
Help support the board
Mongo is offline   Reply With Quote
Old 03-26-2003, 01:09 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Start with a tune up. Plugs, wires, cap and rotor, and a fuel filter too.
That's what I'd do anyways from the sounds of your description.
Old 03-26-2003, 03:16 AM   #7
Hooter
My other Love
Hooter's Avatar
maybe your accelerator pump is goin on the fritz
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 03-26-2003, 03:22 AM   #8
Chevy Wrench
former desert rat
Chevy Wrench's Avatar
Location: salt lake city, utah Home of the 3 M's Mormons, methlabs and minivans
Or, you might try adjusting the air/fuel mixture screws. And possibly the diaphram on your acc. pump has started to leak. Just a thought. By the way, I used to live in Tucson, hows the weather? If you need help with it, I could give you the name of a shop I know of that would be able to help you with it. Pretty good bunch of guys. Good luck.
John
94 Chevy Silverado Ext cab 4/6 drop w/ 18's and 2500watt system (work truck). 67 Chevy swb under const. frame off custom, 20's, bagged and a large rat under the hood,and a 1940 Chevy truck under const.
Chevy Wrench is offline   Reply With Quote
Old 03-26-2003, 03:25 AM   #9
spinning wheels
spinning wheels's Avatar
If the tune-up won't fix the problem. And you don't have a vaccum leak, check the gas sending unit in the gas tank. When I replace mine, the old one was so plugged up, I'm suprised the truck even ran! Good luck.
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 03-26-2003, 08:42 AM   #10
Blue Beard
Blue Beard's Avatar
You might also replace the rubber fuel lines.......both at the tank, and the engine. If these are old they can create the same type of effects.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
