Old 04-18-2011, 01:28 PM   #1
daveccpa
Ford rear end swap
I've decided to use a ford explorer rear end in my 59. I found a 3.73 locker with disk brakes, etc. My question for those that have done this swap before is which springs did you use? The ford's or the old one's from the truck.
daveccpa is offline   Reply With Quote
Old 04-20-2011, 04:30 AM   #2
55dude
55dude's Avatar
Re: Ford rear end swap
stock ones should be fine.
55dude is offline   Reply With Quote
Old 04-20-2011, 08:05 AM   #3
blackdiesel
blackdiesel's Avatar
same here, stock springs
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 04-20-2011, 10:19 AM   #4
solidaxel
solidaxel's Avatar
You can remove 3 leeves and make it ride better if you are using it for a "truck" !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
