04-18-2011, 02:40 PM | #1 |
4x4 air bag suspension?
Anybody know of a air bag suspension for the 69-72 4x4 blazer? Not lowering kit of course. Im building my truck as a daily driver and want a smooth ride.
04-21-2011, 02:20 PM | #2 |
Re: 4x4 air bag suspension?
Good Question! Anybody have anything to say here......
04-22-2011, 10:40 AM | #3 |
needs more $$$
I've never come across a kit for one, but are you thinking about swapping the leafs for a link set up? I just can't see throwing an air bag between the leafs getting you better ride quality.
1970 2wd Blazer |
04-22-2011, 12:03 PM | #4 |
toys'r'us
104" wheelbase + straight axels does not equal smooth ride. I cant see mine being much smoother than it is stock
71 jimmy bone stock 350 sm465 33x12.5 rallies 79 caprice landau full load crate350 th350 lowered 20"wires 00 f150 reg cab sb 4x4 5.4L |
04-22-2011, 05:07 PM | #5 |
The plan is to swap out the leaves for a link set up when I gain the knowledge. For now its just to see if its doable.
04-22-2011, 09:53 PM | #6 |
Everything is do-able with the money.. I gave this sort of a setup some thought years ago. What I would look into would be a F-150 front axle and lift kit front end parts. (I am asuming you want a lift). 6+ inch kits I believe will have longer front arms for the travel and it's all pre-engineered to keep pinion angles ok. and because it is a coil spring settup, it would be ALOT easier to put bags in. But you would want to have limit straps if you offroad it. I know that there once was a kit for later model dodge trucks that was aired down at about 6 inch lift but could go up to about 11 inch lift. A little extreame for a Blazer. With using the f-150 axle however you would have to use a different transfer case cause the pumpkin is on the other side from GM's. The rear axle prolly wouldn't be to hard if you were able to find a link bar setup. I'm sure someone makes somthing out there. But fab skills will have a very large play in this sort settup reguardless. I opted out with the plans because after thinking about it and going wheeling in the brush. There was a good chance of poping the bags with sticks or hard landings. Not to mention the expence of parts just to get it moving. Street rigs and very carefull wheeling would work out just fine I bet. Hope it helps
71 2wd Blazer My build, Restarted 05 Buell firebolt 94 1500 Z71 No rice for me,,, I'm full |
04-22-2011, 10:59 PM | #7 |
I have put bags over springs on the rear, I took 3 leafs out of the pack and used the bags to bring it back level, like you mine will be a daily driver 69 4x4 and want some degree of comfort. I am in the process of the build but now where close to completion.
West
West My Project and Photo Album http://67-72chevytrucks.com/vboard/s...d.php?t=378159 http://67-72chevytrucks.com/vboard/a...hp?albumid=641 |
04-23-2011, 12:37 PM | #8 | |
toys'r'us
04-23-2011, 01:48 PM | #9 |
im in a similar boat- daily driver type build-- but want a bit nicer ride -i know this is limited by solid axles.....even a modest improvement would be nice.
jon |
04-24-2011, 02:17 PM | #10 |
Rollin in my K5 toaster
Leaf springs have limitations. You can pull the leaf springs off completely and build a custom coil over prerunner suspension for the Blazer. Or if money was no object and ride quality was priority. You can buy a 2007 or newer Cadillac Escalade. Pull the body off. Place 69-72 Blazer body on re-sized chassis. Done. Now your K5 will ride like a Cadillac. As long as we are all dreaming.
04-24-2011, 04:37 PM | #11 |
their is a build around here somewhere where someone did this on their 69-72 4x4 truck, so it is doable.
04-24-2011, 04:46 PM | #12 |
here you go bro, i found that thread for yah. enjoy
http://67-72chevytrucks.com/vboard/s...light=4x4+bags |
04-25-2011, 10:37 AM | #13 | |
04-25-2011, 06:06 PM | #14 |
no problem man, glad i could help
03-03-2014, 04:02 AM | #15 |
Hey I know I'm about 3 years late but I'm fairly new to here!...put full air ride on my 4x4 truck...rides like a dream...fully custom setup but well worth it...
03-03-2014, 06:53 AM | #16 |
OK- You need to reproduce that and sell me one!
Side note-I saw a small fifth wheel pulling rig in the parking lot the other day and had to go check it out. I had only the front part of a leaf system and air bags under the rear section. This was stock from the factory I believe. Why wouldn't this work for us? I have an old set of traction bars that come off the top of the axle for axle wrap. A bit limiting for suspension travel but no wrap. Eventually I will put a Heim joint at the front to fix that.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
03-03-2014, 10:48 AM | #17 |
2WD Jimmy
Very very NICE. It Would be a great kit!
03-08-2014, 08:10 PM | #18 |
FNG to resto/mod world!
I would love to see more pics of your airbag setup! Or better yet, I could look at it in person.....
71 GMC Jimmy - under construction 75 GMC K25 Sierra Grande - under deconstruction 92 Chevy K2500 ECSB - sold 04 Nissan Titan ECSB Off Road - sold & missed 13 Ford F-150 Ecoboost (work truck) - sold 16 Ford F-150 Ecoboost (work truck) |
