Old 04-18-2011, 08:19 PM   #1
72tutone
Hazard lights on
I just replaced my electronic panel behind the dash because the temp gauge wasnt working. Now everything works. But when I flip on my headlights I see the hazard light indicators light up on the panel. However the hazard lights are not on. When i pull the hazard lights out they flash accordingly. So what could cause the arrows show up when I pull the headlights?
I'm lost on this one.
72tutone is offline   Reply With Quote
Old 04-18-2011, 08:30 PM   #2
JimKshortstep4x4
Re: Hazard lights on
It could be a ground issue with the circuit or it is possible that the cardboard tubes surrounding the indicators are not sealed and there is light from the dash lights coming into the tubes.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 04-18-2011, 08:38 PM   #3
72tutone
Hmm I will have to check on the cardboard. I never had this issue til I replaced the back panel.
Old 04-18-2011, 10:46 PM   #4
KMACD71
KMACD71's Avatar
My left indicator stayed on when I put my head lights on because my front left signal was burned out. How are your signals in your front bumper. I assume you have a 72.
KMACD71 is offline   Reply With Quote
Old 04-19-2011, 08:14 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
try grounding the inst panel a little batter. I alwways run a ground wire from the steel back of the panel to the dash
