04-18-2011, 08:40 PM | #1 |
Spid info?????
is there any other way to get the info that was on the spid? I have on that is gone. I would like to recreate one when i get to that point in the project.
Wade "DURAMAX BURB" Burb on 2004 chevy 2500HD 4x4 Duramax chassis Long term project 2004 2500HD 4x4 crew cab GMC Duramax 4" lift 35's 79 RS Camaro |
04-18-2011, 09:15 PM | #2 |
Restoration Virgin!
Re: Spid info?????
goto this web site....outintheshop.com
he recreates these
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 04-18-2011 at 09:15 PM. |
04-18-2011, 09:33 PM | #3 |
Re: Spid info?????
If you don't have the original the only other way is to get the build sheet. Those are the only two places to get the options.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
04-18-2011, 10:00 PM | #4 |
Re: Spid info?????
where are the best places to get or find a build sheet
Wade "DURAMAX BURB" Burb on 2004 chevy 2500HD 4x4 Duramax chassis Long term project 2004 2500HD 4x4 crew cab GMC Duramax 4" lift 35's 79 RS Camaro Last edited by DINS 1; 04-18-2011 at 10:00 PM. |
04-18-2011, 10:04 PM | #5 |
Re: Spid info?????
The build sheet is usually either under the seat, between the springs and foam, or behind the seal between the springs and foam. It is not inside the seat, just slipped in between the springs and foam.
04-18-2011, 10:25 PM | #6 |
Roadtrip!
Re: Spid info?????
And it is probably a 50/50 chance you will find the build sheet. If you don't find it, you may never know what options your truck had.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
04-19-2011, 10:20 AM | #7 |
Re: Spid info?????
Here's what it will look like - if it's THERE !!!
. . . . Life is short . . . we only have, right now. . . . . My 70 C-10's BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=475526 |
04-19-2011, 03:06 PM | #8 |
its all about the +6 inches
Re: Spid info?????
looking under/behind the fual tank is another place to locate them, but most are in the seat, and I would say your odds are worse than 50/50 personally.
If it's a nice unmodified clean survivor, then maybe 50/50. If its a well worn old beater, or a restored previouse beater... then I say you have more like 25% or less. |
04-19-2011, 05:33 PM | #9 |
1969 Custom 30 wrecker
Re: Spid info?????
The mice usually have other plans for those. I'd say the odds are 1 in 100.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
