Old 04-18-2011, 08:52 PM   #1
63lemon
63lemon's Avatar
PO _ cluster Question
1.so the previous owner destroyed my 63's instrument cluster, and i want to get this straight, so any 60-66 instrument cluster will work in my truck,
2.when replacing rockers and floor pans, do you do the floor pans first, or rockers first. And does the cab need braced, when cutting floors and rockers
3. What the best stuff to use to paint the frame and other equipment in the undercarriage.
thanks for the help guys, this site and information is great
Ich möchte vroom vroom
63lemon is offline   Reply With Quote
Old 04-18-2011, 09:20 PM   #2
slepysal
slepysal's Avatar
Re: PO _ cluster Question
1. 60-63 are the same ( I have an extra one For cheep if you need one) 64 -66 use a diffrent one
2. not sure
3. por 15
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 04-19-2011, 12:30 AM   #3
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
#2 the inner rocker is partof the floor pan. I would x brace it -cant't hurt, better safe than sorry- then cut out the rockers and floors at the same time, do the floor first, then weld the rocker to it.
just cut out as much of the floor as you need... I usually try to retain as much good factory metal as possible.
alans classic build thread has some good pics of floor/rocker repair, maybe on page 20 or so? he did it early in the build.
Old 04-19-2011, 02:44 AM   #4
Dino Driver
Dino Driver's Avatar
I was doing some searching for parts and ran across something you should look at. He is selling parts and has them all photoed on webshots under the name Colettesbro. I have a 1960 and put the gauge set from a 1 1/4 ton truck...I like the gauges over the idiot lights.
I am doing floor and rockers. I did not do x bracing but if I had to do it again I would. It does not hurt to take a lot of measurements and mark center line of the cab. lots of reference marks will help. But you should only do one side at a time.
There are a lot of ideas about frame paint. Por 15 is good and popular. I'm using a ceramic paint from Eastwood...have not sprayed yet so I can't tell you how good it is. Powder coat is pretty but if you take a rock you can't repair it.
Dino Driver is offline   Reply With Quote
Old 04-19-2011, 11:07 AM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I am curious, what do yall mean by "bracing" when your putting in the floor or rocker?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-19-2011, 11:38 AM   #6
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
To keep the rest of the area in its original position. Simliar to choping a top.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 04-19-2011, 11:56 AM   #7
old chevy truck
Hey if you are still locking for a gage cluster i have one on seattle's craigslist still.
old chevy truck is offline   Reply With Quote
Old 04-19-2011, 05:22 PM   #8
63lemon
63lemon's Avatar
Thanks guys i appreciate it, i will brace the cab to keep it in its original position, I was looking at por-15 but what about KBS? seems good, and a lil cheaper
Old 04-19-2011, 05:33 PM   #9
63lemon
63lemon's Avatar
2. not sure
3. por 15
pm sent
Old 04-23-2011, 12:50 PM   #10
slepysal
slepysal's Avatar
Originally Posted by 63lemon View Post
pm sent
pics sent
