Old 04-18-2011, 08:54 PM   #1
racer57
racer57's Avatar
How Low?
How low can you go without needing an adjustable trackbar? This is on a 71 shortbed.
racer57 is offline   Reply With Quote
Old 04-18-2011, 09:54 PM   #2
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: How Low?
I'd say anything past a 3" drop.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 04-18-2011, 09:59 PM   #3
racer57
racer57's Avatar
Re: How Low?
So if I do like a 2/3 drop I should be okay with the stock trackbar?
Old 04-19-2011, 12:23 AM   #4
SCOTI
SCOTI's Avatar
Re: How Low?
..... if I do like a 2/3 drop I should be okay with the stock trackbar?
The stock Panhard bar will still work @ > 4" drops, it's just not going to be optimum. The greater the drop, the more the rear-end will be shifted to one side. The angle of the bar also has an impact on it's performance. The lower you get w/the bar in the stock location, the farther away from optimum the angle gets.
You could get a 'short' adjustable Panhard bar that mounts just like the original to compensate, but it will still have the undesirable working angle. For a few bucks more, you could get a longer bar (Super track Bar kit) that yields less side shift as the suspension travels (longer bar = less side shift upon suspension compression/extension) & relocates the rearend mount to a better working height for greater than 4" drops.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
