![]() Join Date: Feb 2005
66 Barn doors to clam shell question
Hey guys my suburban has perfect barn doors but I want tailgate and lift gate.I bought some that are rust free.My question is will all suburbans accept the tailgate hinges because I can't tell where they bolt up. I see where the liftgate bolts up but not the tailgate.pics would be great. Thanks in advance.
Re: 66 Barn doors to clam shell question
On my 60 Sub with clam shell doors your can easily see in the vertical body sections where the barn door hinges would be mounted.In my sub the holes have plastic snap-in covers in the not used holes. Mine is a GMC BTW
Bob |
i need rear barn doors
1961 crewcab
seemed to me like the rear pan was different?
I have a barn door sub, and I was looking at that part too, and I could not tell, just curious, because I will keep my barn... I could probably get you a rear pan if they are different (might be $$$ though...), my local wrecking yard has a rollover liftgate sub that I just cut the front floor out of...
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
chevy only
![]() Join Date: Sep 2006
my panel has location for a clam shell(tail gate) but i am not sure either if it will work , but the clam shells are cool but they are a pain in the butt and rattle a ton my opion only
CHEVY ONLY... Nothin Else ! |
I also wanted to do this but it looks to be a ton of work.
Posted via Mobile Device |
Yes you can change to the clam shell but you'll need to replace your rear valance panel where the hinges go thru to the frame................I'll add a picture for you...............All of the mounting points are there but are capped with plastic caps...............Hemmit
Thanks guys,so I'm in search of a rear tail pan for a tailgate sub. I want to collect all the parts before I start the surgery.
I have car A.D.D.
Rather than replacing the complete rear body, once you find one, you may have an easier time building the pockets to clear the hinges. Still some work involved but that obviously doesn't scare you.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
