Old 04-19-2011, 03:23 PM   #1
Greg63
Enjoy your truck
Greg63's Avatar
1963 door weatherstrips - 2 & 4 piece kits
I am trying to figure out what is the correct kit to buy for door weatherstrips for my '63.
There are 2 piece and 4 piece kits. I have seen where the 4 piece kit is for the '60 & '61 trucks but I have also seen ads for the 4 piece kit for the '60-'63 trucks.
I am pretty sure that I can get away with the 2 piece kit on my '63, but what do the other 2 pieces do for me, and can I use them?
Greg.
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 04-19-2011, 03:32 PM   #2
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: 1963 door weatherstrips - 2 & 4 piece kits
There are seals for the doors and ones for the cab. Most probably dont use the ones on the doors. My truck does not have them on the door and I get leaks there and it would help. I think the door seals go across the top and down the front edge of the door to about the hinge. I will get some on my next parts order.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 04-19-2011, 09:21 PM   #3
Greg63
Enjoy your truck
Greg63's Avatar
Who is using the 4 piece set on their '60-'63 and who is using the 2 piece?
I am interested to find out the pro's and cons of each.
Greg.
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
Old 04-19-2011, 11:19 PM   #4
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
on my chopped 61 I did not install the 3rd and 4th pieces... I could not get the doors to stay closed... put the pieces on, and the doors shut nice and tight, must have been just enough outward pressure to keep the latch engaged...
however I have since noticed that all the 62 and 63's I have looked at have just had 2 pieces, not 4
Old 04-20-2011, 03:27 PM   #5
Greg63
Enjoy your truck
Greg63's Avatar
What I don't want to do is spend the extra money for a 4 piece kit and find out that I won't need, or use, the 2 door pieces.
Is the prevailing thinking that the 4 piece kit is not necessary?
Greg
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
Old 04-20-2011, 04:26 PM   #6
61_FL_Apache
Who Me?
The two piece will give you one complete seal around the door. The other two is a double seal for the top and front part of the door. As Jon said, it may be hard to close the door with all seals on there. However, they should mash down in time and take shape.
Im considering buying the second set because of a pass. door leak at the top of the door.
Steve
2001 Blazer 4D 2WD
Old 04-20-2011, 05:59 PM   #7
Greg63
Enjoy your truck
Greg63's Avatar
I am thinking of buying a 2 piece, and using some of my existing door seals (which aren't all bad) to make up the 3rd and 4th pieces.
Greg.
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
