Old 04-19-2011, 04:33 PM   #1
slepysal
slepysal's Avatar
Roller bearing help
I was going to swap out my roller bearings on my 60 with some 68 hubs
My question / problem is on removing the inner race. It seems to be stuck on the spindle. So should I heat it or take a chisel to it?
ANY and I mean ANY help would be great Thanks
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 04-19-2011, 04:48 PM   #2
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Roller bearing help
It's pressed on there. Hopefully someone has an easy method to get them off.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 04-19-2011, 04:59 PM   #3
slepysal
slepysal's Avatar
Thanks!!! I thought it had spun on there
Old 04-19-2011, 05:13 PM   #4
neto
neto's Avatar
It was a pain to take mine out. BFH and had no press. I did it on the axle I have to replace so it was not a big deal. Then I found a site on how to take them out. You drill a hole in it not all the way to the axle then you use a chisel to make a crack in it and slide it out with chisel still in crack. They used a dremel also to cut a grove.
neto is offline   Reply With Quote
Old 04-19-2011, 07:22 PM   #5
slepysal
slepysal's Avatar
Thanks neto , These are on the front might give the Dermal a go
Old 04-19-2011, 08:39 PM   #6
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Remeber safety glasses.
Alan's Classic is offline   Reply With Quote
Old 04-20-2011, 12:04 AM   #7
Captainfab
60-66 Nut
The easiest way is to cut or break it so that it will release it's grip on the spindle. I typically use a 4-1/2" grinder, and grind thru one side of it very carefully so as to not damage the spindle. I know not everyone gas a grinder, but that's just an idea for you.
Old 04-20-2011, 01:11 AM   #8
slepysal
slepysal's Avatar
and a good idea it is !! Good tip on the safety glasses
Old 04-20-2011, 01:46 AM   #9
mr andrerson
I know not everyone gas a grinder>capt
Hey!.... whered you guys get the gas grinders at?!? LOL!
mr andrerson is offline   Reply With Quote
Old 04-21-2011, 06:17 PM   #10
slepysal
slepysal's Avatar
NO!!
