Old 04-20-2011, 02:22 AM   #1
Stepside65
Still Truckless!
Stepside65's Avatar
Transmission? problems
Got to drive the truck for the first time. Reverse worked just fine no issue at all. Forward wasn't quite as good. Something was shaking the entire truck. Anyone have any idea what it might be?
~James
Truckless
2009 Hyundai Sonata<~~Wife's sedanomatic
1997 Nissan Pickup Father-in-law's tonka toy I am forced to drive
Founder of The 60-66 Club
Tutor Et Ultor
Stepside65 is offline   Reply With Quote
Old 04-20-2011, 06:47 AM   #2
scotts62
One day...
scotts62's Avatar
Re: Transmission? problems
Guessing its the '63 and what trans?
Moving to engines and drive train to see if you can get some help on it.
Scott
93 crew cab build
Project 62
Old 04-20-2011, 09:00 AM   #3
Stepside65
Still Truckless!
Stepside65's Avatar
63 with a 350 and a sm420 out of a 74 GMC
~James
Truckless
Tutor Et Ultor
Old 04-20-2011, 04:23 PM   #4
Wrenchbender Ret
The 74 used a SM465 4 speed. It has a larger front retainer where it fits in the bell houseing. Is the face of the trans flush up to the bell housing? If the shaking is when you are engauging the clutch its a clutch problem. If it is after the clutch is engauged then it is probably a driveshaft problem.
Wrenchbender Ret is offline   Reply With Quote
Old 04-20-2011, 05:08 PM   #5
Stepside65
Still Truckless!
Stepside65's Avatar
Trans is flush with bell housing. Only acts up when in a forward gear. As soon a.s it is popped back out of gear it is fine. Talked with some gearheads at work and we came up with the conclusion that it might be severely low on gear oil. Will have to check and report back. The people at the local parts store already know me by name courtesy of this old monster.
~James
Truckless
Tutor Et Ultor
Old 04-20-2011, 09:01 PM   #6
sysock
take a look at your U-joints as well. i had a U-joint going bad in my truck and under acceleration it was fine but deceleration it shook the truck to the point of no return, then when i would take it out of gear it would stop doing it.
sysock is offline   Reply With Quote
