Transfer Case E Brake
Is anybody running Hi Angle Driveline's Emergency brake setup on the rear output of a 205 transfer case? How good is it? Is it a PITA to setup right? I don't like the idea of having to adjust my rear calipers by setting the "E" Brake constantly. Do you think this is the best option? Please let me know what you think! Thanks
1968 K10/30 Frame Off Project "Overkill" My 5 year, $30,000.00 toy |
![]() Join Date: May 2005
Re: Transfer Case E Brake
TTT on this
You should only have to "adjust" couple times a year. On my vehicles where the E brake worked, pull and hold the release handle, back up and depress the E brake pedal. Takes bout 10 seconds to do.
I'm sure it's a good kit, but for the price I'd rather have the other E brake and put the money somewhere else.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
Just wondering does this go along with 14b disc brakes or not if so i found an interesting link awhile back on how to get e-brakes and not have to use those car calipers all the aftermarket companies sell
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
Yeah, that's what I'm trying to get set up...a 14bff. Do you have that link?
http://www.pirate4x4.com/forum/showthread.php?t=887663 although it might be more work i like the idea of a stock like setup over a t-case ebrake or el dorado calipers or whatever they are
Collector of Projects
you can replace the 3/4 ton front calipers that they use on the rear conversioins with the 78ish El Dorado calipers that have an arm for a machanical e-brake....
