How do you remove dashboard to get to evaporator/heater core?
looking for help on how to remove dashboard in a 99 suburban? I need to replace the evaporator and heater core. I tried removing it from the bottom box, but cover won't come off. I was told that you have to from the dashboard. Is this true? is there an easier way? The dashboard won't come off. So for I tried to take apart the bottom of dash and unscrewed the the steering colum and pulled it apart. There is a metal bar that goes left to right that is in the way of the evaporator/heater cor area. I have taken out the front 2 seats (to make more room to work). I have disconnected alot of wires and unscrewed alot of screws. I have been trying to get this dahboard off for 2 days with no luck! Any info. would be great.
Has more rust than truck...
Re: How do you remove dashboard to get to evaporator/heater core?
Welcome to the site! Its a bit long to explain. If you go to autozones site, create an account they have a good write up under repair guides. Good luck, let us know how it goes!
senior member
Even if you google it there's some really good write ups and pictures out there. I just did this job about 3 months ago, have fun!! It was not a pleasant job and a little word of advice is to make sure you watch for the little nipple on the bottom of the heater box. It's the drain for the evaporator and I folded mine over and flooded the cab!!! Maybe you know about this but just thought I'd pass along the pointer.
69 GMC bagged |
