61 Apache Rear Sway bar help.
Was wondering if I can put a rear sway bar on my truck, not sure how it would install, and where to put it, anyone have a rear sway bar setup on their truck?
![]() http://www.classicperform.com/Store/...uck/CP7401.htm |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: 61 Apache Rear Sway bar help.
They go on the trailing arms in front of the axle, at least the after market ones do.
http://www.performanceonline.com/196...BAR-KIT-16840/
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Who Me?
I have seen that before too. It has a curve in to to go over the pumpkin.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
WARNING If it says 60-66 they will not work on your truck. The frame of the 60-62 is much wider than 63 and up. I ordered one from CPP and it was at least 6 inches to short in width. If you find one that says 60-62 with for coil springs I wold call to make sure first. And if you find one that works let me know because I have been looking all over for one.
ok, thanks. i will measure the width and ask CPP what the width is on theirs.
