04-20-2011, 03:25 PM | #1 |
How to drop the front end? How much?
So, I have the engine out of the truck, the front clip is off, the front suspension and steering is out, all I have left is a couple frame rails sticking out from under the cab. Pretty distressing. So I was looking at my spindles and my springs, and decided I could use some new springs. My spindles look okay, other than being covered in sludge. I have new control arm bushings and ball joints to put in. I am running some 275/60R15s on the front. I don't feel compelled to run out and buy any 22s, so I guess I'll stay with what I have there. I don't feel the need to lay rocker, either. So I guess what I am hoping to get from the wealth of knowledge on the subject here is, what parts should I get to drop the truck enough so you can certainly tell it's lowered, but not so low I'm rubbing things and panicking at the sight of a speed bump? Can someone shed a little light on this for me? Any suggestions as to what vendor to use that would have what I need in stock and be able to get it to me quickly? Time is not my friend, even if the truck is not my DD. Thanks for any wisdom you might be good enough to share!
Paul |
04-20-2011, 04:54 PM | #2 |
Re: How to drop the front end? How much?
3" Drop spindles, up front as well as trimming your stock spring. Out back You could just use a flip kit, unless you dont want to do a 4/6 drop. You could always go spindles up front and a hanger/shackle kit out back. You could drop your truck for around $500-$700 depending on weather or not you buy new shocks. With the 275/60/15 I bet you could get away with a 4" drop up front and still have plenty of room, depending on the backspacing of the wheels.
Not sure what vendors would have this stuff, I always forget about them and order through summit or stylintrucks.com which both have extremely fast shipping. Im sure someone will chime in about the vendors. |
04-20-2011, 05:22 PM | #3 |
How much drop do you have on your truck? I like the look of it. Did you use drop spindles and coils up front?
04-20-2011, 05:54 PM | #4 |
I put a flip kit on the back of my ****, with 2.5" spindles and 2" springs on the front...I don't really want it any lower in the back, because I use it as a truck every now and then, but with my setup, I have a slight rake towards the front...If i would do it again, I'd only use 1" springs up front, for a more even ride height front to back. If you use 3" spindles...you're buying new wheels or cutting your control arms.
04-20-2011, 06:23 PM | #5 | |
Its not my daily driver so im not worried about it, But I am going to be doing a full air bag set up because I like the trucks rolling around low on big wheels but I hate having to worry about weather or not I can pull into a parking lot. Its going to be nice to not have to worry any more and just beable to lift it up. If you just want a static drop stick to a 4/6 MAX. |
04-20-2011, 06:24 PM | #6 |
04-20-2011, 07:54 PM | #7 |
Well, crap. Seems like one mod causes others, and before you know it you've spent a lotta ching. I think I put enough into this thing this week. Guess I'll clean what I have maybe replace the springs and call it good for now. I wish I could take this opportunity to go lower, but oh well. Gotta live within my means. Bummer. I need a big sandblasting bay to clean all this mess I got goin on. Ugh, the drudgery!
04-20-2011, 08:50 PM | #8 | |
If you give me all your tire sizes, the back spacing on the wheels, the look your going for, and what your looking to spend I could basically put together a list of part numbers for you to buy so you wouldnt run into any problems. If you want to do something like this, Take a look around the 73-87 Shortbed picture thread and get an idea on how low you want to go. Alot of guys are dropped running 15s so I think you would be able to decide fairly quickly on something you like. Did you see the pictures of my truck with the 15" Centerline wheels? |
04-20-2011, 09:14 PM | #9 |
Wow. That's huge of you to offer. I do appreciate it. And I wish I had the time and the funds to make my truck ride like yours. It looks awesome. So I could do like 2" spindles and maybe 2" drop springs???
04-20-2011, 09:17 PM | #10 |
No problem at all always willing to help someone out. Yes you could possibly do that, do you know the backspace on your wheels? I could give you a better idea if I knew what it was.
04-20-2011, 10:05 PM | #11 |
For a mild, noticable, inexpensive 2/3 drop for under $100: Cut one coil out of the front springs. Add shackles and remove a couple leafs in the back. You'll need the front camber reset. Just did this to mine last week, looks awesome and rides better than stock. My total money spent was $55 for the alignment.
04-20-2011, 10:07 PM | #12 |
That looks really good! I try and tell people to cut their stock springs because everyone says they ride better.
04-20-2011, 10:59 PM | #13 |
Yeah, that looks good. And the price is certainly right. :-)
04-20-2011, 11:51 PM | #14 |
Happy to be here
Nothing wrong with cutting stock springs. Just remember "cut" don't "heat" the springs and you are golden.
04-21-2011, 09:27 AM | #15 |
Is the backspacing the distance between the outside bead of the wheel and the inboard surface of the bolting flange?
04-21-2011, 12:44 PM | #16 | |
Cruzzzn' Vet
http://www.wheelvintiques.com/wordpr...el_fitment.jpg |
04-21-2011, 01:20 PM | #17 |
Looks like backspacing is the distance between the inboard (mating) side of the mounting flange and the inboard bead. Looks like 15 x 8 wheels with 4 inch backspacing.
04-21-2011, 04:47 PM | #18 | |
Do you need to get shorter shocks up front when cutting a coil? can I also put lowering shackles and remove a couple leafs? |
04-21-2011, 05:37 PM | #19 |
I just ordered 2.5 drop spindles and 3" drop springs. Fred is going low.
04-21-2011, 08:50 PM | #20 | |
Yes. I'm using lowering shackles with 2 springs out. Oh yeah, I also removed the rear bump stops to give the rear more travel so the bump stops are not hitting the axle on bumps. |
04-21-2011, 08:56 PM | #21 |
04-21-2011, 09:01 PM | #22 |
Well, I wanted to be careful about the spindles. I was told 3" spindles would make my wheels rub the control arms. So I got the 2.5" spindles, and then went with the 3" coils. Guess I should have asked what problems that would cause. Why is it a bad idea?
04-21-2011, 09:03 PM | #23 | |
04-21-2011, 09:12 PM | #24 |
Eh, if I wind up with wheel troubles I guess I'll have to forego my paint job and get some dubs instead. I like the way Muthstryker's ride sits. It just looks good. Is primer red really that bad??
04-21-2011, 09:15 PM | #25 |
Garage wrench
I like primer red. LOW is where it's at
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
