04-20-2011, 04:23 PM | #1 |
Still Learning
What rear shocks for a 5" drop?
I'm trying to figure out what length or which shock I need to run on my truck in the rear. I made shock relocators that are similar to the ECE style on top HERE and flipped my lower ones HERE to gain a more vertical shock mounting. I know I need a shorter shock just not which one to buy? Any suggestions from guys with a 5" static drop in the rear? Part number? Brand? thanks
04-20-2011, 05:08 PM | #2 |
Re: What rear shocks for a 5" drop?
I did a similar drop on my 68 but w/bags instead of coils & 1.5" CPP lowering blocks U used off the shelf replacement shocks.
With my parts combination & similarly modified shock brackets, the top of the rear ends axle tube was tucked into the frame 1" (it was about 7-8" of drop). Subtract the difference of the blocks & that's 6+ inches of rear drop using factory replacement shocks w/o issue.
04-20-2011, 07:18 PM | #3 | |
Still Learning
04-20-2011, 07:27 PM | #4 |
Nothing to see here.....
I ran 00-07 Tacoma shocks, but that's on a truck that was c notched and bagged. with a 5" static, you'll be getting to the end of an oem shock, but you will still have enough to do the job. I'd roll the stock unless you plan on doing some hauling or hard core corniing.
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
04-20-2011, 08:07 PM | #5 |
The 5" spring drop w/stock shock mounts? Yes, shorter shocks would most likely be needed.
The 5" spring drop w/the shock mounts re-configured to regain 3" of that travel back yields approx 2" difference. I would measure the shock mount dimensions eye to eye @ ride height & compare them to the shocks dimensions. If you currently have the original shocks (what was on there), use them & see how they work if the dimensions are close enough. The rear end hitting the frame/c-notch would limit compression travel before the shocks would on my set-up.
04-20-2011, 08:42 PM | #6 |
Rottenwood Garage Member
I went to the parts store and gave them the KYB 344055 # and crossed it to a monroe shock. Works perfectly on a 3, 4 and 5 inch drop
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
04-21-2011, 12:21 AM | #7 | ||
Still Learning
I got my rear suspension finished tonight here is a pic of the tape measure on the left and right side. It looks like at ride height (without weight of the bed and bumper) it's about 16-3/8" center to center |
04-21-2011, 09:04 AM | #8 |
Anyone have a stock shock they can measure? We need the length @ full extension & compression.
04-22-2011, 12:03 AM | #9 |
A guy with a truck
Monroe 32301: Comp-11.875, Ext-18.250, Diff-6.375
FWIW, I have these on my bagged, 1.5" block, ECE relocators setup and they do not bottom out with the axle buried in the bolt-in c-notch. EDIT: This is a stock replacement shock...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 04-22-2011 at 12:07 AM. |
04-22-2011, 12:17 AM | #10 |
Mcbassin, the math says that's just shy of 2" on extension & 4" compression based on your tape measurement @ ride height. That should work fine.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-22-2011 at 12:18 AM. |
04-22-2011, 01:01 AM | #11 | |
Still Learning
Thanks Scoti. I appreciate your help, and the idea to re-work my shock mounts. |
