Old 04-20-2011, 04:23 PM   #1
68black_betty
68black_betty's Avatar
freeze plug issues
a few weeks ago, i blew out a freeze plug goin down the road, i replaced it with one of those neoprene ones that expand when you tighten them jujst yesterday i blew that one out goin down the highway, now with that being said, before the first one blew out about a week ago my thermostat it was a 190, so i replaced it with a 200, it was either 160 or 200, what im thinkin is would it be possible that with the engine running only ten degrees hotter could expand it that much more to blow out a freeze plug, i checked the other ones and they havent budged at all, or are those neoprene ones just a pos, and does anybody have a tip on how to keep them in, a buddy told me to get one of the steel ones and put some locktite around it
68black_betty is offline   Reply With Quote
Old 04-20-2011, 04:53 PM   #2
cdowns
cdowns's Avatar
Re: freeze plug issues
those neopreme ones are notorious for being bad like that
i've alyays used the proper sized metal ones drove them in and trouble free for many years
Old 04-20-2011, 04:54 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I've always used brass if I could get them. They don't rust like the steel ones.
Old 04-20-2011, 04:59 PM   #4
68black_betty
yeah i know, the other plugs are those steel ones but findong one in the size i need is ridiculous, everyone has 1 5/8 but i need like a 1 7/8
Old 04-24-2011, 02:05 AM   #5
Autoblueprint
Autoblueprint's Avatar
The rubber plugs are designed for temporary use.
Brass expansion plugs are what you want.
Dorman should have the size you need but be ready to do a bit of searching:
http://www.dormanproducts.com/c-250-...ion-plugs.aspx
Autoblueprint is offline   Reply With Quote
Old 04-24-2011, 10:14 AM   #6
cdowns
cdowns's Avatar
NAPA has em all
https://www.napaonline.com/Catalog/Result.aspx
Old 04-24-2011, 10:59 AM   #7
Maxxd07
Maxxd07's Avatar
Brass or steel, I have used both with good luck. Make sure the hole is cleaned up with some emmery cloth or sand paper as well as a light scuff on the plug. Use the green loctite on the plug and drive it in with a socket that fits just inside the "lip". Let it cure and it should hold. Personally I have never had a problem doing it this way.
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
