Old 04-20-2011, 05:08 PM   #1
hotrodhomi
hotrodhomi's Avatar
Ridetech RIDEPRO e3 digital
I have a question about this control unit. I assumed that it looked at the height sensors and made its adjustment, but the features say it uses pressure sensors too. What are the pressure sensors doing? Wouldn't the pressure be different at each corner and depend on slope of the road? Here is a cut an paste from their website.
Features
* - 3 ride height presets with optional "Ride height on start" feature.
* - Optional LevelPro Sensors monitor both air pressure and ride height to eliminate crossloading.
* - Transflective display uses sunlight to illuminate... the brighter the sun, the brighter the display.
* - Mini USB connectors on bottom and back of control panel offer several mounting options.
* - Waterproof ECU allows mounting anywhere on vehicle.
* - Compatible with existing RidePro and other brands of solenoid valves.
* - Built in troubleshooting menus provide error codes to alert users of any malfunctions.
* - Solid state internal compressor relays eliminate external compressor relays and wiring.
* - Waterproof threaded M12 wiring harness connectors.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 04-20-2011, 08:38 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Ridetech RIDEPRO e3 digital
That comment you highlited pretty much sums it up. With the standard Ride Pro system it just monitors air pressure. You set your bags at ride height by pressure. The E3 system has mechanical voltage sensors at each corner to calculate both pressure and height combined.
Old 04-20-2011, 09:16 PM   #3
hotrodhomi
hotrodhomi's Avatar
how can it look at both? Is it using PID control?
'66 impala ht
Old 04-20-2011, 11:37 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
The ECU monitors bag pressure as well as sensor voltage. On initial set up you select the bottom, middle, and top of the range and preset those as 1,2, and 3. The ecu then calibrates and sets the perimeters. If the system see's a change in those perimeters it adjusts accordingly.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-21-2011, 09:56 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Here's video that might help explain better than me...LINK
Articles-
"Refining Sierra"
Old 04-21-2011, 11:27 AM   #6
tech@scottshotrods
Thanks for posting Ken. This is one of a couple features why I like the Ridepro E3 over other ride control systems, by monitoring both pressure and height it assures a faster response to rideheight/proper spring rate time which is almost instant, also by being able to monitor pressure it allows you to trouble shoot small issues if they arise. The Ridepro E3 is by far thee best control system on the market
tech@scottshotrods is offline   Reply With Quote
Old 04-21-2011, 11:59 AM   #7
hotrodhomi
hotrodhomi's Avatar
This looks like a good product but why would it measure 0-5V instead the instrument standard of 1-5 volts? Most instruments use 1-5 volts to allow for a failed signal to be detected. Is there any failure mode if one of the sensors fails?
'66 impala ht
Old 04-21-2011, 12:14 PM   #8
tech@scottshotrods
0-5 is a general term but it is actually 0.5-4.5. There are failure mods and error codes for just about everything with the e-3 from low voltage,air leaks, to a failed sensor. The industry standard for data acquisition is 0.5-4.5 if it does go to 0 it sees that in the software and will throw an error code...
Old 04-21-2011, 12:38 PM   #9
hotrodhomi
hotrodhomi's Avatar
Thanks Jon. Can you PM me a price for the 5 gal, 3/8 valved airpod with ridePro e3 and levelPro?
Also, can you quote me a price on the ridePro system and levelPro sensors? I'm also thinking about upgrading my existing system also. Does the ride pro system come with pigtails to attach the twist connections to my existing system?
'66 impala ht
Old 04-21-2011, 12:41 PM   #10
tech@scottshotrods
I will PM the pricing and to answer your question yes the sensors do come with the wiring harness with attached weather pack connectors...
Old 04-21-2011, 12:44 PM   #11
hotrodhomi
hotrodhomi's Avatar
For clarification, the pigtail I was referring to is the connection between the e3 and my existing valves, the valves are not ridetech.
'66 impala ht
Old 04-21-2011, 12:50 PM   #12
tech@scottshotrods
sorry, which valves are you currently using? btw I will be in sacramento tomorrow
Old 04-21-2011, 01:30 PM   #13
hotrodhomi
hotrodhomi's Avatar
I have SMC valves. After searching a little harder. The twist connections go to the height sensors. I would need the valve block harness. It looks like I can just remove the connectors that plug into the big red valves and solder the in a different style connector to attach my valves. Does the control unit come with this harness?
Going to Sacramento for business or pleasure?
'66 impala ht
Old 04-21-2011, 02:10 PM   #14
tech@scottshotrods
it comes with the valve block harness but it is designed to plug into the ridepro valves, you will need to splice that into your valve wiring harness. I'm going to Sac for pleasure I'm from roseville orig.
