Old 04-20-2011, 05:12 PM   #1
burb71
Active Member
Shift rod, turbo 400
I need the shift rod for my 1968, 396 BB & Turbo 400
I cant find mine, and I dont remember what it looks like, If you have one to sale I'll take it or if you can post a pic of one that may help also
burb71 is offline   Reply With Quote
Old 04-20-2011, 06:39 PM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: Shift rod, turbo 400
confirm with someone else because I just got up from a nap to sleep off a migrane....
...but I think the shift rod itself is the same as any other auto......it's just the piece that mounts to the frame is smaller (a tighter U-shape) than the TH350 one...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 04-20-2011, 07:03 PM   #3
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
I reused my th 350 one?? I guess since I reused all the parts..but when you say shift rod do you mean from the column or the U part??
gotta love not having wheel wells...lol..hope this helps
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 04-20-2011, 07:24 PM   #4
VA72C10
VA72C10
VA72C10's Avatar
I thought that was right
And I think the only reason for the small bracket is with a big block the angle would be bad....probably would have interference with running inner fenders...but you wouldn't need anything different if running a small block with a th400 (for others reference I realize you have the 396)....
..the other option is getting a cpp or Lokar shift linkage. Gives a more positive shift feel....
Old 04-20-2011, 07:29 PM   #5
sjarrett71
sjarrett71's Avatar
I've got a set in my parts thread. Here's the link. (Hope I don't get in trouble)
http://www.67-72chevytrucks.com/vboa...d.php?t=457187
-Scott-
sjarrett71 is offline   Reply With Quote
Old 04-20-2011, 07:33 PM   #6
VA72C10
VA72C10
VA72C10's Avatar
By the way....since this is in the sale section...I do have the smaller frame mount if you decide to go that way Asking 50 shipped for it....
Old 04-20-2011, 07:34 PM   #7
VA72C10
VA72C10
VA72C10's Avatar
No problem since he's looking for the parts and a member
But that frame bracket wouldn't work with his big block and th400...
the rest of the linkage should...
Old 04-20-2011, 07:51 PM   #8
Hottrucks
Hottrucks's Avatar
[QUOTE=VA72C10;4636350]I thought that was right
[QUOTE]
UMMM 472 caddy........... I used the stock th 350 to mount the engine then swapped out the 350 for the BOP th400 I reused the stock linkage and trans coolerr lines..just slip back the trans X member and bolted it all in???
Old 04-20-2011, 08:52 PM   #9
teeitup
Just like to part out trucks!!
teeitup's Avatar
The original turbo 400 rod is different, has a bend in it and I think its a little longer. Th350 will work though.
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 04-20-2011, 09:18 PM   #10
VA72C10
VA72C10
VA72C10's Avatar
Thanks for clarifying....I knew it would work but forgot it was slightly different by the bend and length!
[quote=Hottrucks;4636400][QUOTE=VA72C10;4636350]I thought that was right
I was meaning burb71 had the 396...I knew you had the caddy
I was just posting that someone with a small block and a th400 could use the th350 linkage if they wanted...
Old 04-21-2011, 02:13 AM   #11
burb71
Active Member
Thanks everyone for the help and the pics, now I do remember that rod I cleaned it up very nice on the wire wheel but I cant find it.
Old 04-21-2011, 02:16 AM   #12
t korinek
Truckin' Krazy
t korinek's Avatar
I have a BB t400 shifter rod for $30 shipped
Tom
Dealer for:
American Auto Wire
Precision weatherstripping
Dakota Digital
Trim parts Carpets
Truck World seat covers
& Many others
Chevy Parts locator in Mesa AZ!
t korinek is offline   Reply With Quote
Old 04-21-2011, 08:25 AM   #13
RenoKeene
Florida Edition
RenoKeene's Avatar
Here's a pic of my factory BB th400 linkage, the rod is fairly straight.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 04-21-2011, 04:03 PM   #14
burb71
Active Member
Tom
along with the rod dose it come with the little swivel on the top and what ever I need to attach the rod on the lower end, Cotter pen and spacer or what ever was used.
RenoKeene
Is your set up for sale or are you just showing how the linkage sets up?
Old 04-22-2011, 01:07 PM   #15
RenoKeene
Florida Edition
RenoKeene's Avatar
Originally Posted by burb71 View Post
Tom
RenoKeene
Posted for reference. Hope it helps.
Old 04-22-2011, 08:13 PM   #16
Classic Bowties
Always on the hunt...
Here are a couple of side by side linkage comparison pics that I have been posting for years, first pic shows both of the 2wd w/TH auto setups and the second picture shows the 4wd auto setup next to the 2wd small block w/TH trans setup. Mel
Classic Bowties is offline   Reply With Quote
Old 04-23-2011, 11:37 PM   #17
burb71
Active Member
ttt
Old 04-24-2011, 02:20 PM   #18
burb71
Active Member
ttt
Old 04-24-2011, 04:47 PM   #19
t korinek
Truckin' Krazy
t korinek's Avatar
I have all the OEM pieces for your BB shift set up except the piece that bolts to the trans for $65 shipped.
I have the piece that bolts to the trans new with spring, cotter & washer for addl $15.
Thanks,
Tom
Dealer for:
American Auto Wire
Dakota Digital
Trim parts Carpets
& Many others
Old 04-24-2011, 06:56 PM   #20
burb71
Active Member
Tom I just need the rod, the little slide nut at the top of the rod that hooks to the steering column.
