Old 04-20-2011, 09:47 PM   #1
calvinmitcheal@yahoo
1976 454 Electric Fan???
Guys, I have read alot of the past posts but can't make the final decision without asking directly.
Do I keep the engine driven fan of the 1976 454 that I just swapped into my 1987 chevy truck and create shroud to fit it? Or buy a 4000 cfm dual electric fan set up?
I don't want to spead the $500 on the electric fan set up but want the hp and additional gas mileage aslong as it is going to cool it.
If the electric fan is a good option for my highway driven truck, what minimum CFM do you recommend?
calvinmitcheal@yahoo is offline   Reply With Quote
Old 04-21-2011, 02:21 AM   #2
dmartin1
dmartin1's Avatar
Re: 1976 454 Electric Fan???
i run dual electric fans off of a 2004 ford excursion on mine with a big block radiator(4-row).with no fan and it runs cold.
but our shjortbed with a stock shroud stock good clutch fan etc still runs better.
i like the good clutch fans and shroud.never overheated on me
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 04-21-2011, 05:35 AM   #3
S10Fan
Old Heap Driver
I have a Gen IV big block in my 73, clutch fan from a '79 350, 3 row radiator from an unknown year truck, full fan shroud from another unknown year truck, I have ZERO heating issues.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 04-21-2011, 08:14 AM   #4
tucsonjwt
I have a 454 with stock oil cooler and A/C and granny 4 speed in the AZ desert with stock fan and larger 3 row ReadyRad replacement radiator. I also have no cooling problems, even in 115 degree desert heat. Why not try to stock set up and keep an eye on the temp gauge to see if you need something more? I have had two 454 squares and neither overheated due to fan issues.
tucsonjwt is offline   Reply With Quote
