Old 04-21-2011, 10:42 AM   #1
stich626
th350 space for service
Hello I have my 2 piece driveshaft out as it needed a new center carrier bearing , so I replaced the u joints..
and I'm going to replace the tailshaft seal
my question is does anyone know if there is enough room to slide the th350 back while bolted to the crossmember but crossmember unbolted from frame and drop the converter to change out the front seal ..
thanks..
stich626 is offline   Reply With Quote
Old 04-21-2011, 12:54 PM   #2
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
Re: th350 space for service
that's how i do it. i position my floor jack under the trans pan parallel to the truck, and use a hammer to "tap" on the crossmember. it will slowly walk away from the engine. baby steps though
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 04-21-2011, 08:41 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
i never thought of doing this... there's room, but in reality, I see it as more of a pain than just dropping the trans, and I would be scared of it falling for one reason or another.
Old 04-21-2011, 08:52 PM   #4
hayhauler71
hayhauler71's Avatar
I would drop the cross member and pull the trans if you are installing a front seal. And if the trans is old I also at that time install a new pump seal.
Fuzzy
hayhauler71 is offline   Reply With Quote
