03-25-2003, 07:28 PM | #1 |
dual fan setup??
I have seen then ones that vendors on the board sell, but has anyone ever used fans from a donor vehicle? I was told by a wise mechanic, that you could use dual fans from a dodge caravan for this upgrade. Has anyone done this on a 67-72?
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
03-25-2003, 08:15 PM | #2 |
I HAD A BUDDY RUNNING THEM ON A CAMARO. WORKED FINE. IN FACT, I HAVE THEM NOW. I'M JUST NOT RUNNING THEM BECAUSE THEY WERE TOO WIDE. THEY WENT A LITTLE PAST MY FINNED AREA AND ONTO THE TANKS ON THE RADIATOR. SO THEY WOULDN'T SIT FLUSH. IF YOU WERE LOCAL I WOULD GIVE THEM TO YOU. I'VE BEEN SITTING ON THEM FOR A WHILE. JUST A NOTE I'M RUNNING AN AFTERMARKET RADIATOR(GRIFFIN), WITH A SINGLE FAN AND A THERMOSTAT. NEVER GOT HOT YET.
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd |
03-25-2003, 11:37 PM | #3 |
What all is required to make this work on our trucks..............?
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
03-25-2003, 11:45 PM | #4 |
I have the radiator and fans out of a 94 camaro.
69 SWB LT1/4L60E www.classicplace.com |
03-25-2003, 11:55 PM | #5 |
Do you think the camaro setup would work with the stock truck radiator....?
03-26-2003, 12:01 AM | #6 |
It is almost exactly the same size.
03-26-2003, 12:06 AM | #7 |
It is about 18" tall by 25" wide by 5-1/2" deep. I have the 94 camaro radiator in mine...all I had to do was move the radiator supports (parts with rubber in them) out a little.
03-26-2003, 12:11 AM | #8 |
not the best pic...
03-26-2003, 12:13 AM | #9 |
another...
03-26-2003, 01:00 AM | #10 |
i have a flexalite set up on my 400 small block. had no problems at all
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
03-26-2003, 10:16 AM | #11 |
Post Whore
Someone mentioned in the past that lated 80's to early 90's Furd Taurus use a 2 dual speed fans. Have also heard that Lincoln Mark IV's have a very powerful setup. Check out this link http://www.geocities.com/smithmonte/...rkVIII_Fan.htm
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
03-26-2003, 10:24 AM | #12 |
link no worky
Anyone have a wirng diagram for a dual fan setup? Seems like you should run a 20 amp inline fuse from each fan, have it hooked to an thermostat and an in cab switch??
03-26-2003, 12:57 PM | #13 |
I got 2 fans from a chevy lumina, earlly 90's, they move a lot of air! made my own brakets cause they're set in some plastic crap but they work great. when I hit the switch if its hot idleing it goes from 200 to 180 in less than a min and keeps dropping after. You need a heavy duty relay, when you get the fans hook em up with an old ammeter to see the draw, then you'll know what relay and fuse to get. Good luck!
Jesse
Edmonton, Alberta, 67 c-10, Long fleet, front disks, 5 lug rear end, 327 with Vortechs, edlbrock manifold, comp cams XE 256, 600cfm carb. Backed by a getrag 5 speed and 1 piece driveshaft. 1993 Dihatsu Hijet Jumbo cab 4x4, currently converting to battery electric power. |
03-26-2003, 01:08 PM | #14 |
English Chevy Owner
I'd also put a relay in the circuit to each fan, that way you aren't putting a huge current through your thermostat/switch or trying to thread heavy guage wires through your bulkhead.
The single electric fan in my truck (from something Japanese!) was fitted by the previous owner and was wired without a relay. One day I put my hand up behind the dashboard switch (no thermostatic controller yet) in traffic and found that the switch contacts were too hot to touch due to the huge current drawn by the fan going through the switch. Also when turned off the fan would windmill in the ram air coming in the grille and act as a dynamo and light the switch up...weird! I think Wes has posted a wiring diagram up here before, I'd jsut do a search on electric fan and see what threads you get.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
03-26-2003, 01:14 PM | #15 |
Post Whore
Linky worky for me
03-26-2003, 01:21 PM | #16 |
Not nice to mess with the board members Yukon.................
tried the link, said it would be back in an hour.............sounds like someone went to lunch...........
03-26-2003, 01:27 PM | #17 |
Post Whore
Good ole Geocities! It was in my cache, that why I was still able to pull it up, dang it Dubie, you got me on that one!
Do try to check the link out, there is lots of good info in it on this setup.
03-26-2003, 01:43 PM | #18 |
Yukon, site is back up and running......
That's alot of info to Diegest at one time...........
03-26-2003, 02:50 PM | #19 |
Spank 'em if you got 'em!
Here is a pic of an elec. fan someone posted a while back that I was going to use for imspiration.
Long Knight '71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick |
03-26-2003, 04:00 PM | #20 |
Location: Bondurant, IA but in Worcester, MA for school
I think that picture of the dual fan setup is sold by www.classicheartbeat.com as a kit. I think Im gonna go that route with my truck.
HotRod
1970 Chevy C-20 350 V-8 Turbo 350 w/ shift kit Dana 60 w/ 4.10 gears AND Powr-Loc POSI New Additions: Summit Headers 135amp alternator Proform HEI Edelbrock 1406 600cfm carb Sunpro Tach Powr-Loc POSI Edelbrock Performer RPM Intake MSD 6A Ignition Box AIM: HotRod929 Visit My Site: http://1970chevy.netfirms.com/ |
03-26-2003, 04:17 PM | #21 |
long knight................that would be inspiration...................
03-26-2003, 04:54 PM | #22 |
Seņor Member
Anyone using electric fans care to comment on the noise factor, if any??
Kenneth
03-26-2003, 04:58 PM | #23 |
Right now mine goes WHAAAAAAAAAA! I heard an electric one come on once and it went WHrrrrrrrrr. Hope that helps.
Do electric fans help with mpg?
03-26-2003, 05:10 PM | #24 |
I heard they also help with a small HP gain
03-26-2003, 05:35 PM | #25 | |
Thanks. Cya, Edmond
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb 1974 Chevy Camaro Z28 (Original) ------------------------- Capelle a/d IJssel, The Netherlands |
