Old 04-21-2011, 01:44 PM   #1
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Question 8-Lug Wheel Question
1) Does this type of wheel use the same lug nut as the tapered nuts for OEM steel wheels? I'm thinking about picking one up to replace my split-rim spare.
2) Also, as my studs extend only ~3/16" past the nut with steel wheels, will the aluminum wheel work without longer studs?
3) Lastly, will it be too wide to fit in my OEM under-bed spare carrier with a 235/85-16 mounted? Currently have a 7.50-16 on the split rim -- it's about 8" total width and there's not much apparent capability for anything wider.
Thanks, guys
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 04-21-2011, 06:02 PM   #2
dmack91
dmack91's Avatar
Re: 8-Lug Wheel Question
I believe those take the bugle style lug nuts. They also have a lot of offset. They make the rim run about 2" inside the fender when I tried one on mine - looked odd.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 04-21-2011, 07:10 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Thanks for the reply. I could live with the offset, as it would only be a spare (knock wood, I have never needed to use the spare yet).
Never heard of bugle style lug nuts, so I Googled it. What I found looks similar to an acorn style, but the important thing is the seat appears to be tapered, so maybe my OEM tapered nuts will work. (I'd rather not carry around an extra set of lug nuts just for the spare....)
- Mike -
RIP El Jay
Old 04-21-2011, 08:08 PM   #4
dmack91
dmack91's Avatar
I think the bugle is similar, but the bearing surface is quite a bit larger. Don't know if the taper angle is the same or not, but I think they are.
