04-21-2011, 02:16 PM | #1 |
wiring 73
Hi, need help for wiring my 73. I have a wire marked ign switch start. One end is going to the column ign plug. Where does the other end go. i have an idea it might go to the solenoid side of starter or the hot side terminal. these are new wires from an ez wiring kit. thanks for any help.
04-21-2011, 09:10 PM | #2 |
The One And Only !!!
Re: wiring 73
So much for ez huh ! Taking it as read, That wire would go to the "S" (start) post on the solenoid....
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
