Old 04-21-2011, 03:25 PM   #1
henry3rd
park/ neutral switch
Hey guys,I need help with a connector.I think it is the park neutral switch.
It has six wires.2 pinks,(light green),(dark green and white),(gray )and (black and white).they all go to the c2 connector.I know the two pinks get hooked up ignition hot.what about the other wires?can't find them in the wiring diagrams.Its for a 2003 4.8 that had a 4l60e behind it.I think....
henry3rd is offline   Reply With Quote
Old 04-21-2011, 10:59 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: park/ neutral switch
Go to Autozones web site create an account and click on repair info at the top of the page. They have the wiring diagrams for your truck there, I just looked. I could not find the six wires you're talking about though.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 04-22-2011, 11:16 AM   #3
structures
structures's Avatar
I've attached some schematics. BUT... they're for 2005, the colors are the same but your PNP switch may have letters as opposed to numbers... You can verify by jumping on autozone as usmc said.
Anyway
the dark green goes to C2:F11 and ultimately ties into your starter relay or ignition key (I'm not exactly for sure). This should be tied in to only allow the engine to start in park or neutral
the gray goes to C2:A11 and I believe is your trailer back up line for the trailer connector.
the light green ultimately ties into the stop lamp switch. I mean I really don't know what's going on here but I think it all has to do with the back up lamp circuit.
the blk/wht goes inside the harness and ties into a ground bundle and ultimately goes to the single ground circuit which goes to C2:B7
I hope I've helped out a little. If you can't tell I haven't actually gotten this far so that's why I'm not 100% positive.
Did you remove the transmission range switch signal circuits (the A, B, C and P)?
File Type: pdf 2005 BTSI, BU LP, O2, SEO IGN, TBC IGN 1.pdf (141.2 KB, 165 views)
Robert
1965 Chevy C10
http://67-72chevytrucks.com/vboard/s...d.php?t=374373
1997 Chevy K2500 6.5 diesel
structures is offline   Reply With Quote
Old 04-22-2011, 04:30 PM   #4
henry3rd
Thanks for the wiring diagrams.I'm confused as to what to do with wires.
I know to hook pink to keyed 12 volts but what the others that went to fuse box go to I have no idea.
