Old 04-21-2011, 03:56 PM   #1
mwipp
mwipp's Avatar
factory speaker question..
This is prolly a stupid question but i need some help... Im planning on putting two 4" speakers where the factory speaker went... but i cant find where the original speaker was mounted. if somebody could please help explain where it was mounted it be a great help. a picture would be even better. thank you much
mwipp is offline   Reply With Quote
Old 04-21-2011, 06:33 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: factory speaker question..
There was a pressed steel bracket, that was held in place with two screws, that faced the inside of the cab, under the windshield weatherstrip , where the dash is spot welded to the cowl. There was also a rubber bumper attached to the speaker bracket that rests on the radio. The radio had a bracket that bolted to the cowl as well as the radio. The speaker magnet protruded through the bracket, the top of the speaker has a foam gasket that contacts underneath the dash where the speaker grill is visible.
Old 04-22-2011, 02:05 PM   #3
mwipp
mwipp's Avatar
Thanks much!
