Old 04-21-2011, 04:29 PM   #1
coop34
Brake Distribution Valve Pic/Info
Does anyone have pics or be able to tell me the differences in appearance between a Brake Distribution Valve and a Brake Combination Valve (Proportioning Valve). I have a 70 chevy with a disc conversion and am trying to figure out which one I have.
Thanks!
coop34 is offline   Reply With Quote
Old 04-21-2011, 10:39 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Brake Distribution Valve Pic/Info
ttt
It would be a lot easier if you could post a pic of yours if you are able to.
68gmsee is offline   Reply With Quote
Old 04-21-2011, 10:52 PM   #3
Sammy
Could be wrong. But the distribution Valve doesn't have the centering button and is more square edged shaped the Proportioning Valve has the centering button and has more rounded edges.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 04-21-2011, 11:13 PM   #4
Sammy
Pv
Old 04-22-2011, 01:22 AM   #5
coop34
Here's a pic of what I have. Is this a distribution valve? If so, I am going to the junkyard tomorrow. What kind of vehicle can I snag a proportioning valve from?
Old 04-22-2011, 08:59 AM   #6
Sammy
Looks like it isn't a PV to me..From a gm vehicle with front only disc would be great. Maybe a silverado PU. Get the short lines also into the top from the MC just in case also.
