Old 04-21-2011, 04:40 PM   #1
67chevemall
67chevemall's Avatar
Question Parts list for front disc/drop spindle conversion
Trying to make up a parts list to put drop spindles and disc brakes on a 67..
Any help is awsome...here is what I got so far...:
Drop 2.5" Spindles $200
Spindle nuts and bolts
• 1971 Standard Rotors
• 1971 single piston GM Calipers w/brake pads
• Bearings
• Seals
• Dust caps
• Dust Shields
• Rubber Brake Hoses
• 1971 OEM Proportioning Valve
• 1971 diaphragm booster
Brake fluid
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 04-22-2011, 04:11 PM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Parts list for front disc/drop spindle conversion
Here you go... pulled directly from ECE's website:
Every Kit Comes Complete With Master Cylinder, Proportioning Valve, Brake Lines, Brake Hoses, Calipers, Pads, Rotors, Bearings, Seals, Dust Shields, Dust Caps, Castle Nuts, Slotted Washers, Banjo Bolts, and All necessary Hardware and Brackets.
Make it easy... just give them a call; one stop shop.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 04-22-2011, 04:17 PM   #3
1stchevy
1stchevy's Avatar
I agree with Nate. I just got all my stuff from ECE, great people to deal with.
1stchevy is offline   Reply With Quote
Old 04-22-2011, 04:57 PM   #4
swierker
swierker's Avatar
You can piece all the parts together for a little cheaper than ECE. But... the extra money spent for ECE, makes up for your time saved piecing together parts, piece of mind that you have the correct parts, technical support and great customer service. Worth the extra money, my 2 cents.
Dan
1970 Chevy LWB - 305/350
In Progress: 4/6 ECE drop, front discs, power brakes, Coys C5's.
swierker is offline   Reply With Quote
Old 04-22-2011, 05:06 PM   #5
68Stepbed
68Stepbed's Avatar
Another great thing about buying from ECE is ALL parts to do the swap are included. There's no running to the parts store to get extra things like nuts, bolts, lines or going back and exchanging parts that the parts store got wrong, and beleive me, they will give you some wrong parts.
You're also paying for high quality, "Made In USA" parts from companies like Moog and Raybestos through ECE.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 04-24-2011, 11:31 AM   #6
67chevemall
Thanks guys...I call for their price and go from there...parts source has most of the stuff for pretty cheap and I found a used booster and valve, but have not bought it yet...
Old 04-26-2011, 10:18 AM   #7
67chevemall
$859 plus tax! way too much for this guy. off to the wreckers for a booster, master, valve...
Old 04-26-2011, 07:07 PM   #8
67chevemall
859 plus the master and booster...
I am going with a manual master and proportioning valve
71 rotor and calipers www.partssorce.ca
ECE 2.5 Spindles/bearings/seals
