04-21-2011, 05:16 PM | #1 |
Are the brake lines on separate systems on my 68?
Are the front and back separate or are they all one system? I had a hose go in the front, replaced it and bled it and now all is good. Only the font chamber of the master cylinder was dry.
04-21-2011, 05:22 PM | #2 |
Re: Are the brake lines on separate systems on my 68?
I wanna say its seperate. Look at your master cylinder. If there are 2 resevors(sp?), its a seperate line to front and back. If its one big hole, you have what they called a suicide cylinder and if your hose blew, you had NO brakes. I had a 65 impala that blew a hose and you found out real quick why they called it an emergency brake(grin).
Have fun....don t. .... |
04-21-2011, 07:36 PM | #3 |
Got it, there are two so I think they are independent, thanks.
04-21-2011, 08:27 PM | #4 |
Old Skool Club
The US government took care to make us safer, for '67. AMC was the first to have the system that they called Dual/Diagonal braking. The other manufacturers separated the front from the rear, instead of pairing up one front with the opposite side rear.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
04-21-2011, 10:30 PM | #5 |
Wow, all of the old rigs I have worked on, never knew about AMC's Dual/Diagonal braking. Thanks!
04-22-2011, 08:17 AM | #6 |
Thanks!
