Old 04-21-2011, 09:24 PM   #1
texastrendz
sway bar ?
i am installing nate's sway bar kit on my 72 with a dropmember and factory 73-87 a arms. my question is the sway bar is close to the rack and pinion setup, it is about 2 inches from touching at ride height and is this safe? it will fully cycle without touching. just gets close at some points when traveling the full cycle.
texastrendz is offline   Reply With Quote
Old 04-22-2011, 01:12 AM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: sway bar ?
Yes it is safe... and when you get the other tabs I am making for your factory arms it will give you a little more room. The little angle ones you have in the pics set the bar a little higher.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 04-22-2011, 10:43 AM   #3
texastrendz
Re: sway bar ?
hey nathan thanks for the response. i was expecting the new tabs to be the same dimensions with a porterbuilt twist. i will hold off drilling any hole until i see the new brackets. thanks again, Daniel.
